GPIO access speed
by buteman » Wed Jan 16, 2013 3:24 pm
I am planning to use the GPIO system, about which I know very little at present, I thought I would ask some questions here in the hope I can do what I want.
My questions are:
How fast can they be read?
Can a group of them be read as bits in a port as they can on the arduino?
How fast can they be written to?
Can they be written to as bits of a port?
Can anyone answer these questions please as I have not turned up anything definitive via google searches.
by joan » Wed Jan 16, 2013 3:31 pm
buteman wrote:I am planning to use the GPIO system, about which I know very little at present, I thought I would ask some questions here in the hope I can do what I want.
My questions are:
As fast as you can. You are limited by the processing you do after each read.
Yes, any combination of the user gpios can be read/written in one operation.
As fast as you can, You are limited by the processing you do before each write.
Not sure what you mean. The read/write registers are memory mapped, one 32 bit word covers all the user gpios for read, another for write. If you consider that a port then yes.
by Arjan » Wed Jan 16, 2013 4:05 pm
Using a C library in Linux (for example : http://www.open.com.au/mikem/bcm2835/index.html) you would be able to toggle pins with a 7 MHz frequency max.
Improved performance can be done using bare metal programming.
by joan » Wed Jan 16, 2013 4:46 pm
You don't need to use a C library and its overheads. Just do it in plain C. I'm not sure what use just toggling bits is though, unless the only point is to generate a square wave.
by buteman » Sat Jan 19, 2013 4:02 pm
@ Joan
What I want to do is hook up an 8 bit parallel output ADC to my R.Pi and be able to read the values on all 8 pins in one go. If the pins are connected correctly this would result in a very quick way of finding what the result of the ADC's conversion was as the read would be the 8 bit value.
Or am I completely off track here :?
If I am right perhaps you could give me an example of the code I would need or point me to that code somewhere.
tia
by joan » Sat Jan 19, 2013 6:15 pm
The code at http://abyz.co.uk/rpi/misc/gpio-monitor_v0.c monitors all the gpios (0..53) for state changes. All the user gpios are in bank 1 (gpios 0..31).
If you're familiar with C you could just chop out the few lines of code you actually need (basically initGpio() and a little bit of the main() function).
