DNS does not work - RPi does not advertise itself
by gskillas » Thu Jan 10, 2013 7:54 am
Hello all
I have a small home network with 5 computers on WLAN / Ethernet three with SUSE 12.x one Win7 and the RPi. I am using the router to provide DHCP and DNS services which works for all except the Pi. NMAP shows router, SUSE Box and Pi.
# nmap 192.168.178.0/24
Starting Nmap 6.01 ( http://nmap.org ) at 2013-01-10 08:47 CET
Nmap scan report for speedport.ip (192.168.178.1)
Host is up (0.0023s latency).
Not shown: 997 closed ports
PORT     STATE SERVICE
80/tcp   open  http
443/tcp  open  https
5060/tcp open  sip
MAC Address: 00:1C:4A:24:26:4F (AVM GmbH)
Nmap scan report for 192.168.178.100
Host is up (0.0014s latency).
Not shown: 996 closed ports
PORT     STATE SERVICE
22/tcp   open  ssh
80/tcp   open  http
631/tcp  open  ipp
6566/tcp open  sane-port
MAC Address: B8:27:EB:40:D2:9F (Raspberry Pi Foundation)
Nmap scan report for chalki (192.168.178.105)
Host is up (0.0000040s latency).
PORT    STATE SERVICE
22/tcp  open  ssh
80/tcp  open  http
111/tcp open  rpcbind
Nmap done: 256 IP addresses (3 hosts up) scanned in 7.45 seconds
doing an DNS lookup shows:
# nslookup speedport.ip
Server:         192.168.178.1
Address:        192.168.178.1#53
# nslookup kos
Address: 192.168.178.104
# nslookup chalki
Address: 192.168.178.105
# nslookup alimia
** server can't find alimia: NXDOMAIN
logging into the Pi works via IP:
# ssh 192.168.178.100
root@192.168.178.100's password:
Linux alimia 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Jan 10 02:08:16 2013 from chalki
root@alimia:~# hostname
alimia
and avahi is installed and running. Also I tried setting some more exotic options of dhclient.conf to no avail. Anybody an idea what goes wrong?
Regards
George
by jamesh » Thu Jan 10, 2013 8:21 am
That's a bit odd - mine works out of the box in this fashion. What is the make of the router? Does it have any logs saying connection refused or similar?
Volunteer at the Raspberry Pi Foundation, helper at Picademy September, October, November 2014.
by terrycarlin » Thu Jan 10, 2013 9:50 pm
Did you remember to put the .local after the RPi's hostname when you tried to connect to it? It must be there. I am not sure dnslookup will use the zeroconf/bonjour protocol to find a host. Can't test it right now, but ssh, ping, and other utilities including the browsers will as long as they are on the same network.
If it ain't broke, take it apart and see how it works.
by gskillas » Thu Jan 10, 2013 10:41 pm
@jamesh: The make of the router is a Fritz Box, custom make for the T-com (german telecom service). It is equivalent to a AVM Fritz Box 7170. It has worked with openSUSE (and windows) without a glitch.
@terrycarlin: If you look at the code posted you will notice that the .home (domain) is not needed. That is what happens with and without using it:
root@alimia:~# nslookup chalki
root@alimia:~# nslookup chalki.home
Non-authoritative answer:
Address: 62.X.Y.133
Address: 80.A.B.78
root@alimia:~# nslookup alimia
root@alimia:~# nslookup alimia.home
Address: 62.X.Y.133
Address: 80.A.B.78
Regards
George
by terrycarlin » Thu Jan 10, 2013 11:01 pm
gskillas wrote:@jamesh: The make of the router is a Fritz Box, custom make for the T-com (german telecom service). It is equivalent to a AVM Fritz Box 7170. It has worked with openSUSE (and windows) without a glitch.
Name:
Address: 62.X.Y.133
Address: 80.A.B.78
Address: 62.X.Y.133
Address: 80.A.B.78
Regards
George
Interesting, but did you try to ssh to chalki.home from alimia? I think that when you ssh to chalki.home you will get a connection, but when you ssh to chalki you will not if you don't have chalki in your /etc/hosts file. Make sure chalki is running the avahi-daemon. I use ssh to raspberrypi.local every day from a mac and other raspberrypi(s) and I have never modified anything other than installing avahi-daemon. I do know that if I don't use the .local, the raspberrypi won't be found.
by Polydnj » Fri Jan 11, 2013 2:16 pm
Should you be able to ping raspberrypi.local right out of the box if the machine is on the local network?
by pluggy » Fri Jan 11, 2013 4:15 pm
Polydnj wrote:Should you be able to ping raspberrypi.local right out of the box if the machine is on the local network?
Probably not, is the fair answer. If your router is doing it for you, then yes, but most routers don't. Windows has its own system to do it, but the Pi doesn't have it installed by default. If you installed samba it wold work like the windows system. There are other options, the least painful if you only need a couple of machines to see the pi is to put the pi hostname and IP address in the clients hosts file. All operating systems have them. Windows is usually C:\windows\system32\drivers\etc\hosts or therabouts.
I must not tread on too many sacred cows......
by gskillas » Fri Jan 11, 2013 7:53 pm
terrycarlin wrote:Interesting, but did you try to ssh to chalki.home from alimia? I think that when you ssh to chalki.home you will get a connection, but when you ssh to chalki you will not if you don't have chalki in your /etc/hosts file. Make sure chalki is running the avahi-daemon. I use ssh to raspberrypi.local every day from a mac and other raspberrypi(s) and I have never modified anything other than installing avahi-daemon. I do know that if I don't use the .local, the raspberrypi won't be found.
Ok here you go. chalki is an opensuse box, avahi running out of the box. domain is set to home,
so chalki.home is a FQDN. This is what happens:
Address: 80.156.86.78
Address: 62.157.140.133
root@alimia:~# ssh chalki
Warning: Permanently added the ECDSA host key for IP address '192.168.178.105' to the list of known hosts.
Password:
Last login: Mon Dec 24 11:35:39 2012 from 192.168.178.100
Have a lot of fun...
chalki:~ # exit
logout
Connection to chalki closed.
root@alimia:~# ssh chalki.home
ssh_exchange_identification: read: Connection reset by peer
Now chalki.home does not resolve correctly, chalki does. the /etc/hosts is:
root@alimia:~# cat /etc/hosts
127.0.0.1       localhost alimia.home alimia
127.0.0.2       alimia.home alimia
::1             localhost ip6-localhost ip6-loopback
fe00::0         ip6-localnet
ff00::0         ip6-mcastprefix
ff02::1         ip6-allnodes
ff02::2         ip6-allrouters
#127.0.1.1      raspberrypi
Regards,
George
by gskillas » Sat Jan 12, 2013 9:03 am
terrycarlin wrote:Did you remember to put the .local after the RPi's hostname when you tried to connect to it? It must be there. I am not sure dnslookup will use the zeroconf/bonjour protocol to find a host. Can't test it right now, but ssh, ping, and other utilities including the browsers will as long as they are on the same network.
Actually using .local does not work:
chalki:~> nslookup chalki.local
** server can't find chalki.local: NXDOMAIN
chalki:~> nslookup alimia.local
** server can't find alimia.local: NXDOMAIN
Regards,
George
by efflandt » Sat Jan 12, 2013 5:50 pm
Note that if you have avahi-daemon installed in Linux, and Bonjour in Windows (from Apple, which uses that for zeroconfig), gethostbyname in applications may be able to find names by their hostname.local, even if DNS cannot resolve them:
efflandt@XPS8100-1204:~$ host raspberrypi.local
host: '.local' is not in legal name syntax (empty label)
efflandt@XPS8100-1204:~$ ping -c2 raspberrypi.local
PING raspberrypi.local (172.16.0.102) 56(84) bytes of data.
64 bytes from raspberrypi.domain_not_set.invalid (172.16.0.102): icmp_req=1 ttl=64 time=92.4 ms
64 bytes from raspberrypi.domain_not_set.invalid (172.16.0.102): icmp_req=2 ttl=64 time=17.3 ms
--- raspberrypi.local ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 17.314/54.874/92.435/37.561 ms
efflandt@XPS8100-1204:~$ ssh raspberrypi.local
Linux raspberrypi 3.6.11+ #348 PREEMPT Tue Jan 1 16:33:22 GMT 2013 armv6l
Last login: Fri Jan 11 19:18:05 2013 from xps8100-1204.local
efflandt@raspberrypi ~ $
by gskillas » Sun Jan 13, 2013 10:36 am
@efflandt: Too bad it does not work as advertised:
chalki:~> ping -c2 alimia.local
ping: unknown host alimia.local
@jamesh: I did solve the issue. It involves using dhcpcd instead of dhclient. How to do this is detailed in:
https://wiki.umiacs.umd.edu/VirtualMeshTest/index.php/Enabling_DHCP_client_with_automatic_hostname_allocation
now everything works as expected (TM).
Regards,
George
