a very rookie question
by jorsantander » Wed Jan 09, 2013 10:55 pm
What am supposed to do after I enter user root and pasword root? i want to acces into and frendly grafic ambiace
by pepedog » Wed Jan 09, 2013 11:02 pm
Update first
pacman -Syu
sync
reboot
To install say lxde (the gui) and midori (web browser)
pacman -S xf86-video-fbdev lxde xorg-xinit midori
and to start
xinit /usr/bin/lxsession
The start menu has midori there
If you want to boot into that everytime, without passwords, I will tell you how
by flyinghappy » Wed Jan 09, 2013 11:04 pm
You will need to set up a user, install all the xorg stuff and whatever gui you want be it a desktop environment like Gnome/XFCE/KDE/LXDE or a window manager like OpenBox/DWM/etc. The beginners guide at wiki.archlinux.org has some good useful information for doing some of that kind of stuff.
Pi with ArchLinux running a minidlna/samba home server
by cyrano » Wed Jan 09, 2013 11:13 pm
Type startx and hit enter...
by jorsantander » Wed Jan 09, 2013 11:37 pm
My friend I did all of that, everything was going on well, except fpr this at the end; xinit /usr/bin/lxsession it saiys: xinit command no found
by jorsantander » Wed Jan 09, 2013 11:43 pm
startx command not found
by Cloudcentric » Thu Jan 10, 2013 12:09 am
I know everything about nothing"
by cyrano » Thu Jan 10, 2013 1:38 am
jorsantander wrote:startx command not found
Sorry, my goof. Hadn't seen it was Arch.
by computerchemist » Fri Jan 18, 2013 8:29 pm
thanks a lot pepedog for the advice on this.
I am also a newbie to arch.
I would like to know how to program the pi to auto-start to menu, without # xinit /usr/bin/lxsession ,
and dare I say it, how to un-program it, so can get to the black/white screen again.
Many thanks in advance.
pepedog wrote:Update first
pacman -Syu
sync
reboot
and to start
once upon a time, we all used to be a little baby :-D
by pepedog » Fri Jan 18, 2013 10:48 pm
It's all here https://wiki.archlinux.org/index.php/LXDM#Autologin
Easy way, make sure lxdm is installed if it wasn't installed earlier, or install it also (lxdm is a gui unername/password thang)
pacman -Sy lxdm
Create a new user if root is the only user (I put archuser below but you can use your own imagination), all enters except for password
adduser archuser
Now we edit a file
nano /etc/lxdm/lxdm.conf
look for this line
#autologin=username
change it too
autologin=archuser
You should be able to easily work out ctrl-O saves, ctrl-X quits
Now we get lxdm to start on boot
systemctl enable lxdm
You can always get back to a nornal text login with ctrl-alt-F1
Experiment with ctrl-alt and F1 to F7
by computerchemist » Sat Jan 19, 2013 10:47 am
awesome pepedog :P
many thanks for your expertise.
also found this link to help me out to play around with the login screen if required
http://wiki.manjaro.org/index.php/LXDM_Configuration
by LJH08 » Wed Jan 23, 2013 12:00 am
Thanks for the info everyone!
New to Raspberry Pi myself and trying out different OS's. (Wish the Android port was done!!! )
Played around with Linux on pc , but thats usually with a GUI, a small amount of terminal commands on my mac is about as close to command line code as I get haha! Yal's info and the link helps a lot!
Thanks again.
