Thin client for raspberrt pi.
by Quentin » Wed Jan 09, 2013 2:10 pm
HI all
I need same help urgently . I need a os linux. That’s basically a thin client . that only has my network setting on and Remote desktop.. .please can anybody help me ..
by Cloudcentric » Wed Jan 09, 2013 3:14 pm
Quentin wrote:HI all
Arch Linux Arm is a Command Line Linux Distro and probably a good base to start from:
http://archlinuxarm.org/about
http://www.raspberrypi.org/downloads
I know everything about nothing"
by Quentin » Fri Jan 11, 2013 10:08 am
i downloaded arc . but dont know much about linux. . i also downloaded thinstation but cant get it to boot from the memory card... thinstation is samthing i'm looking for... we going to use the PI to replace our dumb tirmanuls . still testing it to see if it will work. and so far not so good not getting any joy ..... :|
by rpdom » Fri Jan 11, 2013 10:29 am
"Thinstation runs on ordinary PC hardware (32/64 bit i686 class)." (From http://www.thinstation.org/)
The Raspi does not use an i686 class processor. It uses an ARM processor which runs different code. Thinstation will not run on a Raspberry Pi (unless someone creates an ARMv6 version).
You should be able to get the functionality from other packages though, although you might find the Pi a bit slow where graphical screen is involved.
by Cloudcentric » Fri Jan 11, 2013 10:41 am
Quentin wrote:i downloaded arc . but dont know much about linux. . i also downloaded thinstation but cant get it to boot from the memory card... thinstation is samthing i'm looking for... we going to use the PI to replace our dumb tirmanuls . still testing it to see if it will work. and so far not so good not getting any joy ..... :|
Thinstation http://www.thinstation.org appears to be for X86 architecture, the Pi uses the ARMv6 architecture.
Maybe the following will cover what you need:
https://wiki.archlinux.org/index.php/Vnc
https://wiki.archlinux.org/index.php/Rdesktop
https://wiki.archlinux.org/index.php/Main_Page
http://archlinuxpi.blogspot.co.uk
by Quentin » Mon Jan 14, 2013 9:12 am
Thanks for all the help . i got a OS for the raspberry pi that works like a thin client..[b]RPI-TC[/b] is the OS i installed . not to bad.. start testing testing today with the users ... :D
by tmccaffery » Fri Mar 08, 2013 3:38 pm
hello!
sorry for the late comment but my goal is almost exactly the same as yours, i managed to get the pi to boot into rdesktop in around 50 seconds but if they log out it brings them back to the linux desktop, is there anyway to lock it in place?
i also experimented with arch linux but found out you need some sort of desktop session to run rdesktop so it really slows it down
but anyway id love to know how you got on!
by Gbaman » Wed Mar 27, 2013 11:42 pm
There is a much simpler way.
Raspi-TC
(Raspberry pi thin client)
An image built with one intention, a perfect platform for thin clients.
It has rdesktop, Citrix, VMware view and a few others.
Grab it from
http://rpitc.blogspot.co.uk/?m=0
Hope it isn't too late
Do you use Raspberry Pis in a classroom? Would you like your students to be able to log onto any Raspberry Pi in the room and have access to their files. Or maybe be able to easily collect students work? If so, you might want to check our Raspi-LTSP!
pi.gbaman.info
by SuvwI » Tue Apr 30, 2013 9:25 pm
Hi I'm also trying to setup a thin client using Rdesktop.
I have managed to remote onto the windows server and log in automatically (With a little script).
I can then manually start the application I want to run (via a VB Script on the Windows machine).
My question is how can I start the application automatically from running a Linux script on the Pi.
Regards
SuvwI
