ssh over usb?
by peepo » Mon Jan 07, 2013 1:52 pm
is it possible to connect RPI to pc or mac via usb and then ssh?
by tvjon » Mon Jan 07, 2013 2:08 pm
by pksato » Mon Jan 07, 2013 2:11 pm
Or, you can access a serial console using cable like it.
https://www.adafruit.com/products/954
by alexeames » Mon Jan 07, 2013 3:04 pm
peepo wrote:is it possible to connect RPI to pc or mac via usb and then ssh?
USB serial console cable and Putty, which gives you a terminal like ssh does, but it's direct with no network. I did a how-to here...
http://raspi.tv/2012/how-to-run-raspberry-pi-with-no-monitor-or-network
Alex Eames RasPi.TV HDMIPi.com RasP.iO
by gragib » Mon Jan 07, 2013 7:37 pm
You can use an FTDI cable (commonly used for programming Arduino) to connect the Raspberry Pi to a PC using the GPIO pins and then use a serial monitor (e.g. Putty on Windows, CoolTerm on Mac) to log in.
by ghans » Mon Jan 07, 2013 9:11 pm
I think you can use Android phones too , there was a post about
just using a USB cable to SSH in.
ghans
by alexeames » Mon Jan 07, 2013 11:03 pm
ghans wrote:I think you can use Android phones too , there was a post about
ghans
That sounds interesting ghans. Got a link?
by ghans » Tue Jan 08, 2013 5:32 am
I'm not sure if it works with a phone which is offline ...
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=24348
ghans
