Adding commands to boot sequence
by Mobius » Mon Dec 31, 2012 3:47 pm
First does anyone know the sequence of file executions that happens during boot up?
Second, is there a boot file that I can edit to add commands or even better, to add a call to a user file with additional boot commands? I know that Config.txt is probably somewhere near the beginning
of the boot sequence so that is not really a good candidate for what I have in mind. One thing I want to do is to allow for the mounting of a USB drive during boot but I'm sure I'll think of other things as I learn more about Linux and the Pi.
by Jim JKla » Mon Dec 31, 2012 3:53 pm
Config.txt is in the PC acessable part of the SD card acess it with Wordpad NOT NOTEPAD notepad does nor line wrap properly.
There's some noob info here http://elinux.org/RPi_Noob_Guide_to_the_Pi_image#Getting_an_image ;)
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
by flyinghappy » Mon Dec 31, 2012 3:59 pm
To mount a usb drive at boot add it into your fstab file at /etc/fstab.
some good info about fstab here...... https://wiki.archlinux.org/index.php/Fstab
Pi with ArchLinux running a minidlna/samba home server
by Mobius » Mon Dec 31, 2012 7:24 pm
Jim JKla wrote:Config.txt is in the PC acessable part of the SD card acess it with Wordpad NOT NOTEPAD notepad does nor line wrap properly.
I know about editting config.txt but it seems like that is too early in the boot cycle for my purposes. Had to edit it for my HDMI to VGA setup.
by Mobius » Mon Dec 31, 2012 7:29 pm
flyinghappy wrote:To mount a usb drive at boot add it into your fstab file at /etc/fstab.
That is only one example of what I want to do. If there is a boot file where I can just add the mount command line, then that is all I really need for the USB drive. I have already established a "mnt/FLASH" folder so I just need a place to put the "mount -o uid=xxx,gid=xxx /dev/sda1 /mnt/FLASH" command. That would also, presumably, allow me a place to add other command lines.
by Jim JKla » Tue Jan 01, 2013 1:39 am
Thats ok I had to put it in just in case ;)
