Debian Won't Accept pi user
by playzooki » Mon Dec 31, 2012 12:11 pm
I have changed the password for pi user, but when I type in pi at the console when I am asked for the username, it says 'login incorrect'
Also, I the default root password does not work.
Can anyone help?
by elatllat » Thu Jan 03, 2013 10:43 am
you can reset your passwords by plugging the SD into any linux and editing the shadow file;
http://ubuntuforums.org/showthread.php?p=5318038
by playzooki » Sun Jan 06, 2013 2:01 pm
elatllat wrote:you can reset your passwords by plugging the SD into any linux and editing the shadow file;
Please could you explain that in more detail?
by bgirardot » Sun Jan 06, 2013 3:00 pm
Probably an easier way:
Remove the sd card and put it in another machine.
Edit /boot/cmdline.txt file
Add this to the end of the line and keep the whole thing as one line, cmdline.txt can only be one long line:
 init=/bin/bash
Put the sd card back in your raspberry pi and boot up.
After some text scrolls by you will probably have to hit return to get a # prompt.
They type:
passwd pi
And it will prompt you to change the password.
Then type:
sync
Then you have a choice of how to restart depending on what you are most comfortable with.
The easiest thing to do is just unplug the Raspberry Pi, put the SD card back in your other machine and remove the init=/bin/bash you added to the end of the line in cmdline.txt, then put the SD card back into your Raspberry Pi and you should be good to go.
Or you can edit the cmdline.txt file on the raspberry pi itself with these commands:
mount /boot
nano /boot/cmdline.txt
reboot
Maybe that is easier than remove the sd card, I am not sure, I have never done it that way.
