Newbie to RPi setup problems help!!
by Stephen+Dillon » Thu Dec 27, 2012 9:26 am
Hi
 I had a model B for Christmas and have just connected it up to a tv via the HDMI output.
What I have done:
Connect HDMI cable to tv
Connected usb keyboard to onboard socket.
Plugged in a element14 4gb sd card with OP installed
Used a usb powered hub for mouse and power, 1000mA.
I have the message of 'no signal' on the tv and there is a red led on the RPi. I think there was a flashing green led when first powered up.
Can anyone help.
Stephen and son Dillon
by Jim JKla » Thu Dec 27, 2012 9:28 am
Happy Chrismas http://elinux.org/RPi_Lights_but_no_boot
Loads of noob friendly jargon bust stuff on the wiku ;)
If your still stuck postback here ;)
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
by RaspberryPiBeginners » Thu Dec 27, 2012 9:28 am
Connect HDMI cable to tv - Make sure your TV is on the right channel
Plugged in a element14 4gb sd card with OP installed - make sure it's plugged in correctly.
Have you plugged in into the network?
Click here for my unofficial YouTube Channel > http://goo.gl/oFYBD
by Stephen+Dillon » Thu Dec 27, 2012 9:34 am
RaspberryPiBeginners wrote:Connect HDMI cable to tv - Make sure your TV is on the right channel
No I haven't connected to a network. Do I need to
by rurwin » Thu Dec 27, 2012 9:37 am
No.
But in my experience, you have to switch the TV on, and on the right channel, before switching the Raspberry Pi on. If it doesn't detect a TV on HDMI fairly soon after being switched on it decides you're using the composite output.
by Jim JKla » Thu Dec 27, 2012 9:48 am
This applies to some images other than wheezy
http://elinux.org/RPi_Wheezy_config.txt
hdmi_force_hotplug Pretends HDMI hotplug signal is asserted so it appears a HDMI display is attached
hdmi_force_hotplug=1 Use HDMI mode even if no HDMI monitor is detected
by Stephen+Dillon » Thu Dec 27, 2012 9:54 am
Thankyou
I now have a picture using a phono lead.
Stephen
by Jim JKla » Thu Dec 27, 2012 9:58 am
Cool but get your HDMI playing the increased quality is more than worth the effort ;)
by Stephen+Dillon » Thu Dec 27, 2012 10:07 am
I have the Raspi-config screen but no keyboard control.....
Any ideas please.
Stephen
by rurwin » Thu Dec 27, 2012 10:33 am
So you managed to type the username and password, but now can't move around the raspi-config menu? That sounds strange.
You know it's cursor keys to move, Enter to select, and Tab to move between the menu and the "buttons" on the bottom?
by Stephen+Dillon » Thu Dec 27, 2012 10:46 am
All working and HDMI now play connect four.
Thankyou
Stephen
by Stephen+Dillon » Thu Dec 27, 2012 10:59 am
rurwin wrote:So you managed to type the username and password, but now can't move around the raspi-config menu? That sounds strange.
I plugged the keyboard into a powered hub, all ok now.
Thankyou
by Jim JKla » Thu Dec 27, 2012 11:35 am
Bit of Deja vu here
by Jim Manley » Sun Dec 30, 2012 12:57 am
Jim JKla wrote:Bit of Deja vu here
"It's deja vu all over again." -- Major League Baseball catcher Yogi Berra ;)
The best things in life aren't things ... but, a Pi comes pretty darned close! :D
"Education is not the filling of a pail, but the lighting of a fire." -- W.B. Yeats
In theory, theory & practice are the same - in practice, they aren't!!!
