How to turn off a USB disk via hdparm?
by Onira » Mon Dec 24, 2012 6:24 pm
can I turn off a HDD connected via USB using hdparm or any other tool?
its sometimes bit loud at night
Cogito ergo sum
by Mobius » Mon Dec 24, 2012 7:45 pm
Can't you just unplug it from the USB at night?
by Onira » Mon Dec 24, 2012 8:25 pm
it's not a solution
Cogito ergo sum
by efflandt » Tue Dec 25, 2012 12:53 am
Did you read man hdparm in a terminal? You probably want little -y. Not sure if it would wake up on USB if you use capital -Y.
by Onira » Tue Dec 25, 2012 8:13 am
so
$ hdparm -y
do I have to use sudo?
I want to do it via ssh.
Cogito ergo sum
by jheaton5 » Wed Dec 26, 2012 12:16 am
You need to specify the device your are putting to sleep. The command is
hdprm -y /dev/sdx
by efflandt » Wed Dec 26, 2012 5:21 am
Actually: sudo hdparm -y /dev/sda
assuming 1st USB drive
by Onira » Wed Dec 26, 2012 10:24 am
yes, only 1 USB drive is connected (the other USB port is taken by wifi adapter ;) )
so
$ sudo hdparm -y /dev/sda
thank You very much :)
Cogito ergo sum
