What is the desired output from the dad test program?
by ASindleMouat » Sun Dec 23, 2012 6:06 pm
Does anyone know what the desired output looks like for the dad test program?
I fear I may have fried part of my board by removing the IC socket at U6 as I had soldered it in the wrong way round. Only now have I read this post http://www.raspberrypi.org/phpBB3/viewtopic.php?f=42&t=20379. :oops:
Thanks,
Andrew
by alexeames » Sun Dec 23, 2012 8:02 pm
A triangular shape of # characters as the graphical output with two columns of numbers before it. Something like this...
If you leave off the jumper between AD0 and DA1 you will just get the first column of numbers
Alex Eames RasPi.TV HDMIPi.com RasP.iO
by ASindleMouat » Sun Dec 23, 2012 9:50 pm
Thanks Alex for the quick response, I will need to run it again when I get a chance tomorrow but I think it only produced the first column of what looked like hex numbers then the second column which looked like it should have been binary but it was all 0000. I don't think there was a third column.
I had also tried the dtoa program and I was not getting any reading from the multimeter, but I was not sure if I was using it right (I'm a noob with these tools). And I don't have any potentiometers to test the atod program.
by alexeames » Sun Dec 23, 2012 11:02 pm
ASindleMouat wrote:Thanks Alex for the quick response, I will need to run it again when I get a chance tomorrow but I think it only produced the first column of what looked like hex numbers then the second column which looked like it should have been binary but it was all 0000. I don't think there was a third column.
Yes in the C version the first column is hex numbers. In the Python version it's base 10. The second column should be a base 10 number between 0 and 1023 (although it doesn't go all the way up to 1023).
Have you got all the jumpers on the correct ports? You need them on 11, 10, 9, 8 & 7 to their corresponding SCLX,MOSI,MISO,CSnA & CSnD otherwise the A to D and D to A converter chips aren't connected to the SPI bus.
by ASindleMouat » Mon Dec 24, 2012 9:05 am
Oh dear I think I might have found the problem! Rookie mistake, I missed a jumper on 7 :oops:
Thanks very much for your help Alex.
by alexeames » Mon Dec 24, 2012 9:26 am
ASindleMouat wrote:Oh dear I think I might have found the problem! Rookie mistake, I missed a jumper on 7 :oops:
You're welcome.
That's a much better outcome than having damaged the board. :)
by tobes » Thu Dec 27, 2012 8:12 pm
Having successfully got the "Tree" display, I've noticed that the values read are only about 1/3 of the values written, this seems like an awfully large drop to me.
Is this typical, or should I investigate further? Even with the output only going up to 2v, and the input being relative to the 3.3v, I'd have expected "read" values to be more like 2/3 of the output...
by alexeames » Thu Dec 27, 2012 9:01 pm
tobes wrote:Having successfully got the "Tree" display, I've noticed that the values read are only about 1/3 of the values written, this seems like an awfully large drop to me.
The DAC is 8 bit hence the values written to it are from 0-255 (representing 0-2.048V)
The ADC is 10 bit, hence the potential values can go from 0-1023, but in reality, because we are using the DAC in (gain = 1) mode, the maximum voltage it can put out is not 3.3V, but 2.048V.
So if you write 255 to the DAC, you'll read 2.05 Volts, which will correspond to 2.05 / 3.3 * 1023 = 635
Also note if you are using the C version, column 1 is in hexadecimal
