How to use EGL Lock Surface extension?
by dakerfp » Mon Dec 17, 2012 6:11 pm
I've been trying to use the EGL lock surface extension.
I've tried to enable use it in many ways when I decided to look in userland code when I foiund the
table of the EGL configs (userland/interface/khronos/egl/egl_client_config.c):
static FEATURES_AND_FORMATS_T formats[EGL_MAX_CONFIGS] = {
//                                        LOCKABLE
//                                    MASK |
//                R  G  B  A   D  S  M  |  |   COLOR      DEPTH                 MULTISAMPLE           MASK
   {FEATURES_PACK(8, 8, 8, 8, 24, 8, 0, 0, 0), ABGR_8888, DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 0, 24, 8, 0, 0, 0), XBGR_8888, DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 8, 24, 0, 0, 0, 0), ABGR_8888, DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 0, 24, 0, 0, 0, 0), XBGR_8888, DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 8,  0, 8, 0, 0, 0), ABGR_8888, DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 0,  0, 8, 0, 0, 0), XBGR_8888, DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 8,  0, 0, 0, 0, 0), ABGR_8888, IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 0,  0, 0, 0, 0, 0), XBGR_8888, IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 8, 24, 8, 1, 0, 0), ABGR_8888, DEPTH_32_TLBD /*?*/,  DEPTH_COL_64_TLBD,    IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 0, 24, 8, 1, 0, 0), XBGR_8888, DEPTH_32_TLBD /*?*/,  DEPTH_COL_64_TLBD,    IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 8, 24, 0, 1, 0, 0), ABGR_8888, DEPTH_32_TLBD /*?*/,  DEPTH_COL_64_TLBD,    IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 0, 24, 0, 1, 0, 0), XBGR_8888, DEPTH_32_TLBD /*?*/,  DEPTH_COL_64_TLBD,    IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 8,  0, 8, 1, 0, 0), ABGR_8888, DEPTH_32_TLBD /*?*/,  DEPTH_COL_64_TLBD,    IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 0,  0, 8, 1, 0, 0), XBGR_8888, DEPTH_32_TLBD /*?*/,  DEPTH_COL_64_TLBD,    IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 8,  0, 0, 1, 0, 0), ABGR_8888, IMAGE_FORMAT_INVALID, COL_32_TLBD,          IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(8, 8, 8, 0,  0, 0, 1, 0, 0), XBGR_8888, IMAGE_FORMAT_INVALID, COL_32_TLBD,          IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(5, 6, 5, 0, 24, 8, 0, 0, 0), RGB_565,   DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(5, 6, 5, 0, 24, 0, 0, 0, 0), RGB_565,   DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(5, 6, 5, 0,  0, 8, 0, 0, 0), RGB_565,   DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(5, 6, 5, 0,  0, 0, 0, 0, 0), RGB_565,   IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(5, 6, 5, 0, 24, 8, 1, 0, 0), RGB_565,   DEPTH_32_TLBD /*?*/,  DEPTH_COL_64_TLBD,    IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(5, 6, 5, 0, 24, 0, 1, 0, 0), RGB_565,   DEPTH_32_TLBD /*?*/,  DEPTH_COL_64_TLBD,    IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(5, 6, 5, 0,  0, 8, 1, 0, 0), RGB_565,   DEPTH_32_TLBD /*?*/,  DEPTH_COL_64_TLBD,    IMAGE_FORMAT_INVALID},
   {FEATURES_PACK(5, 6, 5, 0,  0, 0, 1, 0, 0), RGB_565,   IMAGE_FORMAT_INVALID, COL_32_TLBD,          IMAGE_FORMAT_INVALID},
#ifndef EGL_NO_ALPHA_MASK_CONFIGS
   {FEATURES_PACK(8, 8, 8, 8,  0, 0, 0, 8, 0), ABGR_8888, IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID, A_8_RSO},
   {FEATURES_PACK(8, 8, 8, 0,  0, 0, 0, 8, 0), XBGR_8888, IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID, A_8_RSO},
   {FEATURES_PACK(5, 6, 5, 0,  0, 0, 0, 8, 0), RGB_565,   IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID, A_8_RSO},
#endif
   {FEATURES_PACK(5, 6, 5, 0, 16, 0, 0, 0, 0), RGB_565,   DEPTH_32_TLBD,        IMAGE_FORMAT_INVALID, IMAGE_FORMAT_INVALID},
Apparently, the lock bits is disabled for every acceptable EGL config.
It has the extension, but does RPi really supports texture lock?
If it does, how can I do it?
Thanks.
by dom » Mon Dec 17, 2012 6:27 pm
From 3D guy:
"I don't think we support it in any useful way, no."
Moderator
Moderator
by dakerfp » Mon Dec 17, 2012 8:09 pm
dom wrote:From 3D guy:
I have a few
Why It's not supported?
What is lacking for support it?
Is it a hardware issue or a software one?
Is it on the roadmap?
There isn't any workaround?
Thanks,
by blu » Fri Dec 21, 2012 9:03 am
I have a few
Thanks,
I remember bumping into the same issue when I was trying to get a fast userspace->GPU upload path couple of months ago. EGL_KHR_lock_surface is pretty much a zombie extension in the current BRCM stack.
