Setting up a printer
by mihau » Mon Dec 17, 2012 3:32 pm
Have someone tried to install a printer? No matter how I installed the hplip (from the repo, executable from the official page, even compiled myself with appropriate setting) I still cannot print anything. The printer itself (HP LaserJet Professional p1102) seems to install without any problems, but it won't print. Neither with a hpcups driver nor a hpijs driver.
What I've found out (from the error log):
D [17/Dec/2012:15:24:04 +0100] [Job 31] sh: 1: hpijs: not found
D [17/Dec/2012:15:24:04 +0100] [Job 31] GPL Ghostscript 9.05: Can't start ijs server "hpijs"
However, the hpijs has been installed and is present in the system.
The printer works fine with Debian Squeeze (6.0.6) on my other machine.
by mihau » Mon Dec 17, 2012 10:42 pm
Ok, so I compiled latest hplip with hpijs support. Now it can 'print'. EVerything seems ok, but the printer doesn't even react. No errors in log, it's just like the files are going into the ether.
by bteeter » Mon Dec 17, 2012 11:16 pm
just install cups which is a standard unix/linux printing system.
apt-get install cups
Bob Teeter
by mihau » Mon Dec 17, 2012 11:23 pm
I have just removed everything associated with hplip, removed the printer, added new printer via CUPS and set the driver to Foomatic/foo2zjs-z2. And it worked!
by daremick » Tue Dec 18, 2012 5:07 am
mihau wrote:I have just removed everything associated with hplip, removed the printer, added new printer via CUPS and set the driver to Foomatic/foo2zjs-z2. And it worked!
you said "added new printer" what was the new printer model? Or did you mean you just re-installed the 1102w?
by mihau » Tue Dec 18, 2012 10:17 am
Reinstalled.
