GIS on Raspberry Pi
by mrtenchy » Wed Oct 03, 2012 10:35 pm
Just a quick topic about what GIS packages people have got to run on their Raspberry Pi.
So far i have got working
    Navit (car navigation) and
    GRASS - no problems at all
These are both on a Raspbian Wheezy HardFloat OS. (Turbo boosted of course!) :P
by GeoPi » Tue Nov 06, 2012 5:34 am
Hi mrtenchy,
I'm yet to receive my RPi, and it could be a while yet. I'm also interested in the GIS capabilities of this device, and was hoping to run GeoServer on it. I haven't quite decided what I'm going to use it for, but my tentative plan is to try and interface it with a remotely located arduino, receive GPS serial data via a wireless Xbee module and write it to PostGIS.
I'll have more details when (if) I receive this thing in the next year or so.....
by Seahawk79 » Sat Nov 24, 2012 11:29 pm
I have been thinking about qgis, but the holy grail will be when we can access the GPU for processing tasks - someday...
vector based GIS should be pretty straightforward though, with the camera module be interesting to see possibilities for AR
by Maille » Thu Dec 27, 2012 1:27 pm
I got a second pi for christmas so considering putting geoserver on to it but not too sure if I'll be able to.
by Maille » Thu Dec 27, 2012 1:48 pm
From an initial look it appears the soft float version of debian should be required in order to use java;
http://www.raspberrypi.org/downloads
http://macgyverdev.blogspot.ie/2012/08/ ... omcat.html
http://docs.geoserver.org/stable/en/use ... n/war.html
Once I get home to fast internet I'll download and give it a go
by xranby » Thu Dec 27, 2012 5:25 pm
Maille wrote:From an initial look it appears the soft float version of debian should be required in order to use java;
Both OpenJDK and the Oracle JDK 8 JVM supports hard float
"The latest Java 8 release is hard float, which is a good thing, because it gives you better performance and the recommended Raspberry Pi build is also hard float. Stay away from anything that says soft, softfp, etc., because it will be incompatible with the hard float JVM."
http://javafx.steveonjava.com/javafx-on ... asy-steps/
You can combine the OpenJDK runtime classes with the Oracle JDK 8 JVM to run headfull X11 AWT/Swing applications, there is no reason to use soft-float Debian Wheezy image any more.
viewtopic.php?p=238541#p238541
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
by adlambert » Thu Dec 27, 2012 6:25 pm
I don't know if PostGres is ported to linux on ARM, but I know it supports spatial datatypes.
by Redrobes » Thu Dec 27, 2012 7:39 pm
I will be porting ViewingDale which is not GIS but is more like GeoServer to the Pi. It uses the GPU for most of the processing so with a 512Mb version and a 128Mb GPU mem split then it should work ok. Im not sure how fast it will run tho but the app is designed for slow CPU, fast GPU hardware which is ideal for the Pi. See viewingdale.com or put viewingdale into youtube to see it on windows. The port may take a while to do tho. I have the ViewingDale dice running on linux but not under OpenGL ES2 yet.
