changing cmdline.txt gives ERROR::handle_hc_chhltd_intr_dma
by Sander » Mon Sep 03, 2012 9:37 am
Trying to solve USB Bluetooth problems, based on https://github.com/raspberrypi/linux/is ... nt-8099236 , I added "dwc_otg.microframe_schedule=1 dwc_otg.speed=1" to /boot/cmdline.txt. However, booting results in a loop with a lot of these errors:
ERROR::handle_hc_chhltd_intr_dma:2040: handle_hc_chhltd_intr_dma: Channel 0, DMA Mode -- ChHltd set, but reason for halting is unkown, hcint 0x00000002, intsts 0x06000021
After reverting the change, I could boot again (but USB BT problem still there).
So: what am I doing wrong? Typo? Or is a newer kernel (no 3.1.9+) or newer firmware needed?
Screendump:
Old:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline   rootwait
New, not booting:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline dwc_otg.microframe_schedule=1 dwc_otg.speed=1  rootwait
by Licaon_Kter » Wed Sep 05, 2012 10:20 am
Since you follow the kernel development on that site you will notice that patches get pushed and these cmdline.txt options suddenly appear, but since that kernel is already at 3.2.27 and beyond things won't magically appear in 3.1.19 :(. So like yeah, 3.2.27 is needed. Any reason not to upgrade yet?
BFQ+BFS or RT on a RPi? 4'real: https://github.com/licaon-kter/ (source and compiled!)
by Sander » Wed Sep 05, 2012 12:24 pm
Licaon_Kter wrote:Since you follow the kernel development on that site you will notice that patches get pushed and these cmdline.txt options suddenly appear, but since that kernel is already at 3.2.27 and beyond things won't magically appear in 3.1.19 :(. So like yeah, 3.2.27 is needed. Any reason not to upgrade yet?
I've upgraded the system to 3.2.27, and get other problems; see my reports under the account 'sanderjo' on that site. To be short: the system blocks if/when USB keyboard and/or mouse are connected and the two extra settings are in cmdline.txt. :(
