Keyboard remapping broken on X-windows ?
by Binson » Mon Sep 03, 2012 4:56 am
Hi All !
As i was preparing for may first attempt at compiling anything ever * i remarked that my a's came out as q's . After some searching on this forum i hit on a subject** and posted this :
Quote/
Am having the same problem as Johann : Belgian keymap (azerty iso qwerty, etc) is used in the console, but as soon as i use X lxde the mapping reverts to qwerty . This is on a fresh install of the official raspbian, with latest updates of firmware, software et al .
I also installed an sd card with pisces MATE R2, did all the updates and upgrades, and Bingo! Qwerty in the GUI . In MATE one can set the keymap in the preferences, but this shows the be(lgian) map duly set .
I can't recall having this problem when i first installed the official raspbian image, few hours after it came out, so it's got to be one of the upgrades to the x innards thats the culprit, hence this mayday call .
end quote/
I have rewritten the MATE sd-card with an original raspbian image and can confirm remapping works correctly in an un-upgraded X-lxde session on my machine . I can keep this image for now to run some upgrade tests, but don't know where to start . The fully upgraded wheezy armel image that i also have does not exhibit this flaw btw .
Thanks for reading .
Binson
* want to compile Synergy 1.4.10 on PI to be able to use it as server with my Macbook as client, but thats andother story
**http://www.raspberrypi.org/phpBB3/viewtopic.php?f=50&t=7278&p=163542#p163542
by thsBavR10 » Mon Sep 03, 2012 3:49 pm
I have the same problem,
(keyboard mapping is in gnome different to bash, qerty istead of qwertz (german)),
and i can't find an option in gnome to change the remapping. there is no option in settings.
Has anybody made an custom xorg.conf or an other solution?
Thanks!
by thsBavR10 » Mon Sep 03, 2012 4:30 pm
I've found an workaround:
inserting the line
setxkbmap -option grp:ctrl_shift_toggle,grp_led:scroll  de,de
in the file /etc/X11/xinit/xinitrc
(before calling . /etc/X11/Xsession) helps.
You have only to insert the mapping at the end of the line.
by Binson » Tue Sep 04, 2012 1:56 am
Hi All !
Thanks thsBavR10 for putting me on the right track .
The file you mentioned did not have any entries so i just added in
setxkbmap be
and it worked !!!
Forcing it in this way does not explain what, or how, it got broken in the first place though .
Hmmm ...
Bye for now .
Binson
by thsBavR10 » Tue Sep 04, 2012 10:22 am
I am pleased that it has helped.
But this is, as you wrote, only a workaround, not a final solution.
Something has broken between the individual changes at the console to locale and keyboard-mapping and so on,
and the X11 / LXDE.
Don't know, where to adress this error (maybe in the rasbian board).
by Sleep Mode zZ » Tue Sep 04, 2012 10:33 am
I can confirm this problem. I'm not sure when I last time typed something in X, I noticed this only now.
by brutus » Fri Nov 30, 2012 9:32 am
Same problem for me, mz swiss kezboard work fine under the standard bash but switch to Uk or US kezboard as soon as I run LXDE, as zou can see :)
by brutus » Fri Nov 30, 2012 12:37 pm
thsBavR10 wrote:I've found an workaround:
Thanks, it work for me except that I used the Swiss - French keyboard
setxkbmap -option 'grp:ctrl_shift_toggle,grp_led:scroll' 'ch(fr)'
by ausinch » Fri Dec 21, 2012 11:50 pm
My problem is my Swiss German does work right from the start.
BUT the Alt Gr button will not work - so I cant get a backslash or AT symbol.
I have run "sudo raspi-config" and set the k/b again (configure_keyboard) but to no avail
by thsBavR10 » Sat Dec 22, 2012 11:25 am
AltGr is working for me, both on commandline and in X11.
What does your /etc/default/keyboard contain regarding XKBMODEL ?
XKBMODEL="pc105"
I also have this file:
cat /etc/X11/xorg.conf.test :
# only sectionInputDevice for testing
Section "InputDevice"
   Identifier   "Generic Keyboard"
   Driver   "kbd"
   Option   "XkbRules"   "xorg"
   Option   "XkbModel"   "pc105"
   Option   "Xkblayout"   "de"
EndSection
by ausinch » Mon Dec 24, 2012 11:05 am
My Alt Gr key works now.
I didnt do anything to get it going it just started working. I did change the power supply on the pi to a hub and connected the wireless USB transmitter to the hub, it could have been a power issue.
Here's my config file anyway:
cat /etc/default/keyboard
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="logicda"
XKBLAYOUT="ch"
XKBVARIANT=""
XKBOPTIONS="lv3:ralt_switch,terminate:ctrl_alt_bksp"
BACKSPACE="guess"
