Tutorial: How to install Chocolate Doom w/ sound on Raspbian
by Johnyz » Fri Nov 02, 2012 9:40 pm
Hey everybody,
since there are quite a few articles about playing Doom using Chocolate Doom on Arch Linux, but none about Raspbian, I decided I'd write one! First, I have to warn you. Unlike Arch Linux, where you can install this software with the package manager, here we have to compile it, since it doesn't seem to be in the repositories yet.
First off, we need to prepare a folder for the source code. I have a folder called Sources in my home directory where I direct all my source code and compiling related needs. So, let's start by creating one:
cd ~
mkdir Sources
cd Sources
Next, we will download the .tar.gz archive from SourceForge either with Midori or NetSurf or download it on your computer and use SSH to transfer it to the Sources folder:
http://downloads.sourceforge.net/project/chocolate-doom/chocolate-doom/1.7.0/chocolate-doom-1.7.0.tar.gz
Then unpack it, delete the archive and navigate into the new folder:
tar -xvf chocolate-doom-1.7.0.tar.gz
rm chocolate-doom-1.7.0.tar.gz
cd chocolate-doom-1.7.0
Before we start configuring and compiling, we need to download a pretty huge list of packages, they are mainly SDL related so they should be useful to you on your next compiling adventures.
sudo apt-get update
sudo apt-get install gcc build-essential libsdl1.2-dev libsdl1.2debian libsdl-image1.2 libsdl-image1.2-dev libsdl-mixer1.2 libsdl-mixer1.2-dev libsdl-net1.2 libsdl-net1.2-dev timidity
When everything is installed, we can finally run the configuration script.
./configure
(NOTE: If this gives you an error, it is most likely due to a part of your compiling masquerade is missing. Try googling the error and you will most likely find what you need to apt-get in order to fix it.)
Finally, we can start compiling. This will take some time but not nearly as long as Q3A.
make
After compiling finishes, we will install our new binaries with the followning command:
sudo make install
NOTE: You need to run this using sudo or as root, because the installing script copies binaries, icons and .desktop files to the /usr/share folder. On the bright side, this means that everything gets neatly embedded in your LXDE menu. Due to the way chocolate-doom is launched this is a bit unneeded, but we will talk about that later (at least we have the icon).
To configure Chocolate Doom, you need to run the following command from the terminal:
chocolate-setup
This will bring you up a nice DOS-looking window where you can configure our new software. Under display configuration, you can either choose the full screen, but if you have a Full HD LCD like me, I reccomend hitting A, disabling "Fix aspect ratio" and then selecting 1280x800, since it tends to be quite laggy on full 1920x1080. Hit the escape key to return to the original menu. Since there is no joystick to be configured, we will head right to the keyboard configuration. If you want controls similar to more modern FPS games, set Move Forward to W, Move Backward to S, Strafe Left to A, Strafe Right to D and you can set Turn Left to Q and Turn Right to E or whatever you like and leave Speed On on Shift and Strafe On on Alt. Press escape to return and you can skip the Mouse configuration, since everything there is set by default to the "average" levels. You can fiddle around there yourself later. Go to Sound configuration and make sure Sound Effects is set to Digital and that Music playback is set to Native MIDI. Once you checked that, return to the main menu and select Save parameters and launch DOOM. Now, since there are no WAD files yet, the game will not lauch but the settings will be saved.
Now, we need to get the WAD files. A little google search will tell you how to *cough* *cough* extract these files from your original Doom CD. Alternatively, you can use Doom 2, Ultimate Doom, TNT: Eviluion or Plutonia. Log into your Raspberry Pi through SSH as root (for example using WinSCP) and make create a folder called doom in /usr/share and put your doom.wad, doom2.wad, tnt.wad or plutonia.wad. I have tried Strife and Hexen as well, but for some strange reason they don't work for me.
Then you can finally start the game using the terminal with the following command:
chocolate-doom -iwad /usr/share/(name of your file).wad
Congratulations! You have now got Doom running on your Raspberry Pi.
OPTIONAL: Create a WAD-specific launcher so you don't have to use the terminal all the time
Open up LeafPad and type the following text in:
[Desktop Entry]
Name=Doom 1
Exec=chocolate-doom -iwad /usr/share/doom/doom.wad
Icon=chocolate-doom
Type=Application
Comment=Conservative Doom source port. Loaded with a Doom1 WAD.
Categories=Game;ActionGame;
And save it on your desktop as doom1.desktop. The exact name doesn't really matter, since the name specified inside the file is the one getting displayed. Bang, you got your easy desktop launcher for Doom. Can you even ask for more? Well... Of course you can. Let me introduce you to the:
OPTIONAL 2: Create a laucher for multiple kinds of Doom using Zenity
So, let's say you happen to own both Doom 1, Doom 2, and on top of it you also own TNT and Plutonia. And you don't want to have four different icons. Then let us create a launcher with all these options! Using a little inspiration from the ever-popular Python Games, we will make ourselves a nice little menu using Zenity. Open up LeafPad, or, if you have it, Geany and paste the following script there:
#!/bin/sh
RET=0
GAME=$(zenity --list --width=350 --height=250 --radiolist --title="Choose your game" --column "Select" --column="Game" TRUE "Doom 1/Ultimate Doom" FALSE "Doom 2" FALSE "TNT: Evilution" FALSE "The Plutonia Experiment"  )
RET=$?
echo $GAME
if [ "$GAME" = "Doom 1/Ultimate Doom" ]; then
elif [ "$GAME" = "Doom 2" ]; then
   chocolate-doom -iwad /usr/share/doom/doom2.wad
elif [ "$GAME" = "TNT: Evilution" ]; then
   chocolate-doom -iwad /usr/share/doom/tnt.wad
elif [ "$GAME" = "The Plutonia Experiment" ]; then
   chocolate-doom -iwad /usr/share/doom/plutonia.wad
else
   echo "Cancelled..."
fi
And save it somewhere nice, like your home folder, under the name chocolate-doom-launcher (without the extension). Open up terminal, navigate to the file you just saved and issue these two commands:
chmod +x chocolate-doom-launcher
sudo cp chocolate-doom-launcher /usr/bin
From now on, you have a new terminal command that brings up a nice little launcher for all your Doom related business. Now let's turn it into a pretty little icon, shall we? For the last time, open LeafPad or Geany and create a new file and paste this into it:
[Desktop Entry]
Name=Chocolate Doom Launcher
Exec=chocolate-doom-launcher
Icon=chocolate-doom
Type=Application
Comment=One launcher for all Doom realted games.
Categories=Game
And save it on your desktop as chocolate-doom-launcher.desktop. If you want this launcher to appear in your menu as well, open up terminal for the last time and type in these two commands:
cd ~/Desktop
sudo cp chocolate-doom-launcher.desktop /usr/share/applications
And that's it. You now have a fully working, configured installation of Chocolate Doom 1.7.0 with working MIDI sound thru Timidity, with a launcher for different games both on your desktop and in your applications menu. Time to give yourself a pat on the back, and go play some Doom! :arrow: Enjoy!
Sources of some information used: viewtopic.php?p=83495 http://www.sparkfun.com/tutorials/372
by billb » Sat Nov 03, 2012 12:24 am
Excellent tutorial -- very well written. Thanks!
I've noticed you can run it straight from the terminal as well (without launching X), as long as you choose an 8-bit video mode in chocolate-setup. Hard to tell what resolution its actually running at, though my terminal is at 1920x1080 when I launch it.
And I see timidity launching at startup every time now, using a small amount of memory and no CPU time. Not really a concern for me with a 512MB Pi.
by Johnyz » Sat Nov 03, 2012 9:21 am
Thanks the heads up about running without X! I didn't know that. Timidity launches because it is used to play back the music, beacause we selected it during installation. You can also select the OPL AdLib emulation (I just verified that works too), but the music is pretty quiet even at max volume, plus MIDI offers better quality as well.
by LeSanglier » Sun Jan 20, 2013 8:12 pm
Thank you Johnyz !
I can now play Doom on my Raspberry Pi !! :D
Mon blog sur le Raspberry Pi : http://framboisepi.fr/
Pour avoir plus de chance d'avoir une réponse à votre question,
allez sur le forum français Rasberry Pi : http://forum.raspfr.org
by UsefulDoor » Sun Jan 20, 2013 10:37 pm
How do you use SSH to transfer it to the Sources folder?
by LeSanglier » Mon Jan 21, 2013 9:24 am
From a linux computer that has all .wad :
[~] ➔ cd JEUX/DOOM/Wads
[~/JEUX/DOOM/Wads] ➔ ls
doom2.wad doom.wad heretic.wad hexen.wad prboom.cfg tnt31.wad tranmap.dat
doomu.wad freedoom.wad hexdd.wad plutonia.wad prboom.wad tnt.wad
[~/JEUX/DOOM/Wads] ➔ scp *wad pi@192.168.1.100:/home/pi/JEUX/DOOM/Doom
192.168.1.100 : the ip address of the raspberry pi
/home/pi/JEUX/DOOM/Doom : The directory on the raspberry pi where they will have wads
by 6677 » Tue Jan 22, 2013 3:58 pm
How this did not turn up when I was searching for how to get doom on the pi will forever be beyond me.
As for hexen not working. Hexen used a slightly updated form of the engine. Chocolate doom aims to be near identical to the original doom engine including original bugs. It doesnt support the extra hexen extensions. You need the raven branch of chocolate doom for that to work: http://www.chocolate-doom.org/wiki/inde ... ven-branch
by QBall1977 » Tue Mar 12, 2013 6:12 am
Brilliant,
Thanks for the tutorial, well written, executed and thought out. You should do more.
:D :D :D :D :D
A DOOM is now over 7 years old has it not fallen out of copyright? I think the Carmack et al would approve of this approach.
____________________________________________
Looking for where to start - try Kernel Panic - http://goo.gl/EEQ5J
by CerialPhreak » Wed Mar 13, 2013 1:46 am
I'm going to try to add this to EmulationStation. I haven't installed yet, but will I be able to configure Chocolate to use my usb gamepad?
by Profusion44 » Wed Jul 03, 2013 4:04 am
I have followed the steps here for installing chocolate doom. I get all the way to the part where I enter chocolate-setup at the terminal and I get a response like this:
bash: chocolate-doom: command not found
This occurs whether I am in the "~/Sources/chocolate-doom-1.7.0 $" or the setup folder within the directory I just mentioned. It also yields the same response at the initial command line whe opening terminal.
I am a bit new to Linux and terminal usage, so I assume I am just missing some trivial steps somewhere. If anyone has any suggestions I would like to hear them.
I'm on raspberry pi model b running raspbian OS installed using the NOOBS image.
This is happening on a mostly fresh install of the OS. Aside from upgrade updates and the chocolate doom related files, I ran only one other command at the terminal to install a package manager.
Sudo apt-get install synaptic -y && gksudo synaptic
Thanks again.
by antiriad » Fri Dec 27, 2013 4:27 pm
I'd like to install chocolate Doom on my rPi, but I don't like the fact that timidity run at boot occupying (also a small amount of) RAM. There is a way to avoid this?
Thank you!
by Vanfanel » Sun Dec 29, 2013 3:23 pm
@antiriad:
Look for the timidity service launch script in /etc/init.d
Let's say it's something like "/etc/init.d/timidity".
Now simply disable that script: "sudo insserv -r timidity"
by antiriad » Sun Dec 29, 2013 3:41 pm
Vanfanel wrote:@antiriad:
Thank you for your support.
So I suppose it will need to be loaded manually before running Chocolate DOOM?
Another question: is Chocolate DOOM fully compatible with Heretic and Hexen WADs?
(I really don't like PrBoom, I can't get it running at all...)
by Vanfanel » Sun Dec 29, 2013 5:31 pm
I don't know, Antiriad. But the best option for Doom-ing on the Pi is, BY FAR, using the RetroArch port of PrBoom, wich runs with GLES accelerated graphics (yes, we have GLES DOOM on the Raspbery Pi) along with MP3 music :)
by antiriad » Sun Dec 29, 2013 5:39 pm
This surely sound interesting, but it is possible to install this Retroarch port without using a pre-made SD card image? I mean: I would like to add manually emulators and portings to my config. I'd like also to run Doom without entering in X. There is a tutorial? Thanks
by Vanfanel » Sun Dec 29, 2013 6:00 pm
antiriad wrote:This surely sound interesting, but it is possible to install this Retroarch port without using a pre-made SD card image? I mean: I would like to add manually emulators and portings to my config. I'd like also to run Doom without entering in X. There is a tutorial? Thanks
Of course there is! I wouldn't touch one of these pre-made SD images with a 10mts pole. The fun is in having these things running by yourself, learning and enjoying some fast commanline action to play!
Look here for my RetroArch on Pi tutorial. I believe the PrBoom core is not covered, but it's the same as with other cores:
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=56070
Have lots and lost of fun! Oh, and try to use distcc to build these things or it will be a painfully slow process :P
If you don't feel like building yourself, ask me for prebuilt binaries and I will post them.
by antiriad » Wed Jan 01, 2014 5:36 pm
Vanfanel wrote:...
Thank you for your help and suggestion.
It is possible maybe to have the binaries?
The compilation process gives me the following error:
LD retroarch
gfx/gl.o: In function `gl_compute_fbo_geometry':
/home/pi/RetroArch/gfx/gl.c:381: undefined reference to `glGetIntegerv'
gfx/gl.o: In function `gl_create_fbo_textures':
/home/pi/RetroArch/gfx/gl.c:464: undefined reference to `glGenTextures'
/home/pi/RetroArch/gfx/gl.c:494: undefined reference to `glTexImage2D'
/home/pi/RetroArch/gfx/gl.c:469: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:479: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:480: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:481: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:482: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:506: undefined reference to `glTexImage2D'
/home/pi/RetroArch/gfx/gl.c:520: undefined reference to `glBindTexture'
gfx/gl.o: In function `gl_create_fbo_targets':
/home/pi/RetroArch/gfx/gl.c:528: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:529: undefined reference to `glGenFramebuffers'
/home/pi/RetroArch/gfx/gl.c:532: undefined reference to `glBindFramebuffer'
/home/pi/RetroArch/gfx/gl.c:533: undefined reference to `glFramebufferTexture2D'
/home/pi/RetroArch/gfx/gl.c:535: undefined reference to `glCheckFramebufferStatus'
/home/pi/RetroArch/gfx/gl.c:543: undefined reference to `glDeleteFramebuffers'
gfx/gl.o: In function `gl_init_fbo':
/home/pi/RetroArch/gfx/gl.c:623: undefined reference to `glDeleteTextures'
gfx/gl.o: In function `gl_set_texture_frame':
/home/pi/RetroArch/gfx/gl.c:2620: undefined reference to `glGenTextures'
/home/pi/RetroArch/gfx/gl.c:2621: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:2622: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2623: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2624: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2625: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2633: undefined reference to `glPixelStorei'
/home/pi/RetroArch/gfx/gl.c:2637: undefined reference to `glTexImage2D'
/home/pi/RetroArch/gfx/gl.c:2650: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:2628: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:2645: undefined reference to `glTexImage2D'
gfx/gl.o: In function `gl_read_viewport':
/home/pi/RetroArch/gfx/gl.c:2354: undefined reference to `glPixelStorei'
/home/pi/RetroArch/gfx/gl.c:2356: undefined reference to `glReadPixels'
/home/pi/RetroArch/gfx/gl.c:2350: undefined reference to `glBindFramebuffer'
gfx/gl.o: In function `gl_update_input_size':
/home/pi/RetroArch/gfx/gl.c:1015: undefined reference to `glPixelStorei'
/home/pi/RetroArch/gfx/gl.c:1022: undefined reference to `glTexSubImage2D'
gfx/gl.o: In function `gl_free_overlay':
/home/pi/RetroArch/gfx/gl.c:1562: undefined reference to `glDeleteTextures'
gfx/gl.o: In function `gl_overlay_load':
/home/pi/RetroArch/gfx/gl.c:2449: undefined reference to `glTexImage2D'
/home/pi/RetroArch/gfx/gl.c:2441: undefined reference to `glGenTextures'
/home/pi/RetroArch/gfx/gl.c:2442: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:2443: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2444: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2445: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2446: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2448: undefined reference to `glPixelStorei'
gfx/gl.o: In function `gl_free':
/home/pi/RetroArch/gfx/gl.c:1600: undefined reference to `glDeleteTextures'
/home/pi/RetroArch/gfx/gl.c:1604: undefined reference to `glDeleteTextures'
gfx/gl.o: In function `gl_deinit_fbo':
/home/pi/RetroArch/gfx/gl.c:554: undefined reference to `glDeleteTextures'
/home/pi/RetroArch/gfx/gl.c:555: undefined reference to `glDeleteFramebuffers'
gfx/gl.o: In function `gl_deinit_hw_render':
/home/pi/RetroArch/gfx/gl.c:637: undefined reference to `glDeleteRenderbuffers'
/home/pi/RetroArch/gfx/gl.c:635: undefined reference to `glDeleteFramebuffers'
gfx/gl.o: In function `gl_init_hw_render':
/home/pi/RetroArch/gfx/gl.c:647: undefined reference to `glGetIntegerv'
/home/pi/RetroArch/gfx/gl.c:648: undefined reference to `glGetIntegerv'
/home/pi/RetroArch/gfx/gl.c:654: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:655: undefined reference to `glGenFramebuffers'
/home/pi/RetroArch/gfx/gl.c:682: undefined reference to `glBindRenderbuffer'
/home/pi/RetroArch/gfx/gl.c:683: undefined reference to `glRenderbufferStorage'
/home/pi/RetroArch/gfx/gl.c:685: undefined reference to `glBindRenderbuffer'
/home/pi/RetroArch/gfx/gl.c:688: undefined reference to `glFramebufferRenderbuffer'
/home/pi/RetroArch/gfx/gl.c:690: undefined reference to `glFramebufferRenderbuffer'
/home/pi/RetroArch/gfx/gl.c:713: undefined reference to `glCheckFramebufferStatus'
/home/pi/RetroArch/gfx/gl.c:673: undefined reference to `glBindFramebuffer'
/home/pi/RetroArch/gfx/gl.c:674: undefined reference to `glFramebufferTexture2D'
/home/pi/RetroArch/gfx/gl.c:704: undefined reference to `glBindRenderbuffer'
/home/pi/RetroArch/gfx/gl.c:705: undefined reference to `glRenderbufferStorage'
/home/pi/RetroArch/gfx/gl.c:707: undefined reference to `glBindRenderbuffer'
/home/pi/RetroArch/gfx/gl.c:708: undefined reference to `glFramebufferRenderbuffer'
/home/pi/RetroArch/gfx/gl.c:721: undefined reference to `glBindFramebuffer'
/home/pi/RetroArch/gfx/gl.c:667: undefined reference to `glGenRenderbuffers'
gfx/gl.o: In function `gl_query_extension':
/home/pi/RetroArch/gfx/gl.c:108: undefined reference to `glGetString'
gfx/gl.o: In function `gl_init_textures':
/home/pi/RetroArch/gfx/gl.c:1158: undefined reference to `glGenTextures'
/home/pi/RetroArch/gfx/gl.c:1162: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:1164: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:1165: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:1166: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:1167: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:1178: undefined reference to `glTexImage2D'
/home/pi/RetroArch/gfx/gl.c:1184: undefined reference to `glBindTexture'
gfx/gl.o: In function `gl_set_viewport':
/home/pi/RetroArch/gfx/gl.c:822: undefined reference to `glViewport'
gfx/gl.o: In function `gl_init':
/home/pi/RetroArch/gfx/gl.c:2013: undefined reference to `glGetError'
/home/pi/RetroArch/gfx/gl.c:2015: undefined reference to `glGetString'
/home/pi/RetroArch/gfx/gl.c:2016: undefined reference to `glGetString'
/home/pi/RetroArch/gfx/gl.c:2019: undefined reference to `glGetString'
/home/pi/RetroArch/gfx/gl.c:2026: undefined reference to `glBlendFunc'
/home/pi/RetroArch/gfx/gl.c:2117: undefined reference to `glDisable'
/home/pi/RetroArch/gfx/gl.c:2118: undefined reference to `glDisable'
/home/pi/RetroArch/gfx/gl.c:2119: undefined reference to `glDisable'
gfx/gl.o: In function `gl_check_error':
/home/pi/RetroArch/gfx/gl_common.h:63: undefined reference to `glGetError'
gfx/gl.o: In function `resolve_extensions':
gfx/gl.o: In function `gl_set_shader':
/home/pi/RetroArch/gfx/gl.c:2271: undefined reference to `glBindTexture'
gfx/gl.o: In function `gl_update_tex_filter_frame':
/home/pi/RetroArch/gfx/gl.c:2223: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:2224: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2225: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2226: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2227: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/gl.c:2231: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:2294: undefined reference to `glDeleteTextures'
gfx/gl.o: In function `gl_frame':
/home/pi/RetroArch/gfx/gl.c:1415: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:1446: undefined reference to `glDisable'
/home/pi/RetroArch/gfx/gl.c:1447: undefined reference to `glDisable'
/home/pi/RetroArch/gfx/gl.c:1448: undefined reference to `glDisable'
/home/pi/RetroArch/gfx/gl.c:1449: undefined reference to `glDisable'
/home/pi/RetroArch/gfx/gl.c:1450: undefined reference to `glDisable'
/home/pi/RetroArch/gfx/gl.c:1451: undefined reference to `glBlendFunc'
/home/pi/RetroArch/gfx/gl.c:1452: undefined reference to `glClearColor'
/home/pi/RetroArch/gfx/gl.c:1465: undefined reference to `glClear'
/home/pi/RetroArch/gfx/gl.c:1480: undefined reference to `glDrawArrays'
/home/pi/RetroArch/gfx/gl.c:1512: undefined reference to `glBindTexture'
gfx/gl.o: In function `gl_frame_fbo':
/home/pi/RetroArch/gfx/gl.c:932: undefined reference to `glBindFramebuffer'
/home/pi/RetroArch/gfx/gl.c:936: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:938: undefined reference to `glClear'
/home/pi/RetroArch/gfx/gl.c:949: undefined reference to `glDrawArrays'
/home/pi/RetroArch/gfx/gl.c:962: undefined reference to `glBindFramebuffer'
/home/pi/RetroArch/gfx/gl.c:966: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:968: undefined reference to `glClear'
/home/pi/RetroArch/gfx/gl.c:980: undefined reference to `glDrawArrays'
gfx/gl.o: In function `gl_render_overlay':
/home/pi/RetroArch/gfx/gl.c:2525: undefined reference to `glEnable'
/home/pi/RetroArch/gfx/gl.c:2536: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:2543: undefined reference to `glDrawArrays'
/home/pi/RetroArch/gfx/gl.c:2546: undefined reference to `glDisable'
/home/pi/RetroArch/gfx/gl.c:2551: undefined reference to `glViewport'
/home/pi/RetroArch/gfx/gl.c:1469: undefined reference to `glClear'
gfx/gl.o: In function `gl_check_fbo_dimensions':
/home/pi/RetroArch/gfx/gl.c:877: undefined reference to `glBindFramebuffer'
/home/pi/RetroArch/gfx/gl.c:878: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:880: undefined reference to `glTexImage2D'
/home/pi/RetroArch/gfx/gl.c:885: undefined reference to `glFramebufferTexture2D'
/home/pi/RetroArch/gfx/gl.c:887: undefined reference to `glCheckFramebufferStatus'
gfx/gl.o: In function `gl_start_frame_fbo':
/home/pi/RetroArch/gfx/gl.c:849: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:850: undefined reference to `glBindFramebuffer'
/home/pi/RetroArch/gfx/gl.c:1429: undefined reference to `glBindTexture'
gfx/gl.o: In function `gl_copy_frame':
/home/pi/RetroArch/gfx/gl.c:1209: undefined reference to `glPixelStorei'
/home/pi/RetroArch/gfx/gl.c:1249: undefined reference to `glTexSubImage2D'
/home/pi/RetroArch/gfx/gl.c:1438: undefined reference to `glBindFramebuffer'
gfx/gl.o: In function `gl_draw_texture':
/home/pi/RetroArch/gfx/gl.c:1348: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/gl.c:1354: undefined reference to `glEnable'
/home/pi/RetroArch/gfx/gl.c:1358: undefined reference to `glViewport'
/home/pi/RetroArch/gfx/gl.c:1359: undefined reference to `glDrawArrays'
/home/pi/RetroArch/gfx/gl.c:1360: undefined reference to `glViewport'
/home/pi/RetroArch/gfx/gl.c:1365: undefined reference to `glDisable'
/home/pi/RetroArch/gfx/gl.c:2528: undefined reference to `glViewport'
/home/pi/RetroArch/gfx/gl.c:1363: undefined reference to `glDrawArrays'
/home/pi/RetroArch/gfx/gl.c:1221: undefined reference to `glPixelStorei'
/home/pi/RetroArch/gfx/gl.c:1222: undefined reference to `glTexSubImage2D'
/home/pi/RetroArch/gfx/gl.c:1226: undefined reference to `glPixelStorei'
/home/pi/RetroArch/gfx/gl.c:1234: undefined reference to `glTexSubImage2D'
gfx/fonts/gl_raster_font.o: In function `setup_font':
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:266: undefined reference to `glEnable'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:272: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:301: undefined reference to `glDrawArrays'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:306: undefined reference to `glDrawArrays'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:312: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:314: undefined reference to `glDisable'
gfx/fonts/gl_raster_font.o: In function `adjust_power_of_two':
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:142: undefined reference to `glTexImage2D'
gfx/fonts/gl_raster_font.o: In function `blit_fonts':
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:206: undefined reference to `glPixelStorei'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:207: undefined reference to `glTexSubImage2D'
gfx/fonts/gl_raster_font.o: In function `gl_deinit_font':
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:75: undefined reference to `glDeleteTextures'
gfx/fonts/gl_raster_font.o: In function `gl_init_font':
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:35: undefined reference to `glGenTextures'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:36: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:37: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:38: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:39: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:40: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:41: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/fonts/gl_raster_font.c:42: undefined reference to `glGetIntegerv'
gfx/shader_glsl.o: In function `gl_glsl_set_attribs':
/home/pi/RetroArch/gfx/shader_glsl.c:548: undefined reference to `glBindBuffer'
gfx/shader_glsl.o: In function `gl_glsl_set_vbo':
/home/pi/RetroArch/gfx/shader_glsl.c:539: undefined reference to `glBufferData'
/home/pi/RetroArch/gfx/shader_glsl.c:558: undefined reference to `glEnableVertexAttribArray'
/home/pi/RetroArch/gfx/shader_glsl.c:559: undefined reference to `glVertexAttribPointer'
/home/pi/RetroArch/gfx/shader_glsl.c:567: undefined reference to `glBindBuffer'
gfx/shader_glsl.o: In function `compile_shader':
/home/pi/RetroArch/gfx/shader_glsl.c:397: undefined reference to `glShaderSource'
/home/pi/RetroArch/gfx/shader_glsl.c:398: undefined reference to `glCompileShader'
/home/pi/RetroArch/gfx/shader_glsl.c:401: undefined reference to `glGetShaderiv'
gfx/shader_glsl.o: In function `print_shader_log':
/home/pi/RetroArch/gfx/shader_glsl.c:338: undefined reference to `glGetShaderiv'
/home/pi/RetroArch/gfx/shader_glsl.c:347: undefined reference to `glGetShaderInfoLog'
gfx/shader_glsl.o: In function `gl_glsl_set_mvp':
/home/pi/RetroArch/gfx/shader_glsl.c:1087: undefined reference to `glUniformMatrix4fv'
gfx/shader_glsl.o: In function `gl_glsl_set_params':
/home/pi/RetroArch/gfx/shader_glsl.c:906: undefined reference to `glUniform2fv'
/home/pi/RetroArch/gfx/shader_glsl.c:909: undefined reference to `glUniform2fv'
/home/pi/RetroArch/gfx/shader_glsl.c:912: undefined reference to `glUniform2fv'
/home/pi/RetroArch/gfx/shader_glsl.c:923: undefined reference to `glUniform1i'
/home/pi/RetroArch/gfx/shader_glsl.c:930: undefined reference to `glActiveTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:931: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:932: undefined reference to `glUniform1i'
/home/pi/RetroArch/gfx/shader_glsl.c:944: undefined reference to `glActiveTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:945: undefined reference to `glUniform1i'
/home/pi/RetroArch/gfx/shader_glsl.c:946: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:952: undefined reference to `glUniform2fv'
/home/pi/RetroArch/gfx/shader_glsl.c:955: undefined reference to `glUniform2fv'
/home/pi/RetroArch/gfx/shader_glsl.c:1027: undefined reference to `glActiveTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:1028: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:1029: undefined reference to `glUniform1i'
/home/pi/RetroArch/gfx/shader_glsl.c:1035: undefined reference to `glUniform2fv'
/home/pi/RetroArch/gfx/shader_glsl.c:1038: undefined reference to `glUniform2fv'
/home/pi/RetroArch/gfx/shader_glsl.c:1062: undefined reference to `glActiveTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:1074: undefined reference to `glGetUniformLocation'
/home/pi/RetroArch/gfx/shader_glsl.c:1075: undefined reference to `glUniform1f'
/home/pi/RetroArch/gfx/shader_glsl.c:919: undefined reference to `glUniform1i'
/home/pi/RetroArch/gfx/shader_glsl.c:973: undefined reference to `glActiveTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:974: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:986: undefined reference to `glUniform2fv'
/home/pi/RetroArch/gfx/shader_glsl.c:989: undefined reference to `glUniform2fv'
/home/pi/RetroArch/gfx/shader_glsl.c:981: undefined reference to `glUniform1i'
/home/pi/RetroArch/gfx/shader_glsl.c:1008: undefined reference to `glActiveTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:1009: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:1017: undefined reference to `glActiveTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:1018: undefined reference to `glBindTexture'
gfx/shader_glsl.o: In function `gl_glsl_deinit':
/home/pi/RetroArch/gfx/shader_glsl.c:674: undefined reference to `glUseProgram'
/home/pi/RetroArch/gfx/shader_glsl.c:680: undefined reference to `glDeleteProgram'
gfx/shader_glsl.o:/home/pi/RetroArch/gfx/shader_glsl.c:680: more undefined references to `glDeleteProgram' follow
gfx/shader_glsl.o: In function `gl_glsl_reset_attrib':
/home/pi/RetroArch/gfx/shader_glsl.c:529: undefined reference to `glDisableVertexAttribArray'
/home/pi/RetroArch/gfx/shader_glsl.c:704: undefined reference to `glDeleteBuffers'
/home/pi/RetroArch/gfx/shader_glsl.c:702: undefined reference to `glDeleteBuffers'
gfx/shader_glsl.o:/home/pi/RetroArch/gfx/shader_glsl.c:702: more undefined references to `glDeleteBuffers' follow
/home/pi/RetroArch/gfx/shader_glsl.c:684: undefined reference to `glDeleteTextures'
gfx/shader_glsl.o: In function `gl_glsl_use':
/home/pi/RetroArch/gfx/shader_glsl.c:1172: undefined reference to `glUseProgram'
gfx/shader_glsl.o: In function `compile_program':
/home/pi/RetroArch/gfx/shader_glsl.c:426: undefined reference to `glCreateProgram'
/home/pi/RetroArch/gfx/shader_glsl.c:436: undefined reference to `glCreateShader'
/home/pi/RetroArch/gfx/shader_glsl.c:443: undefined reference to `glAttachShader'
/home/pi/RetroArch/gfx/shader_glsl.c:449: undefined reference to `glCreateShader'
/home/pi/RetroArch/gfx/shader_glsl.c:456: undefined reference to `glAttachShader'
gfx/shader_glsl.o: In function `link_program':
/home/pi/RetroArch/gfx/shader_glsl.c:409: undefined reference to `glLinkProgram'
/home/pi/RetroArch/gfx/shader_glsl.c:412: undefined reference to `glGetProgramiv'
gfx/shader_glsl.o: In function `print_linker_log':
/home/pi/RetroArch/gfx/shader_glsl.c:360: undefined reference to `glGetProgramiv'
/home/pi/RetroArch/gfx/shader_glsl.c:369: undefined reference to `glGetProgramInfoLog'
/home/pi/RetroArch/gfx/shader_glsl.c:417: undefined reference to `glUseProgram'
/home/pi/RetroArch/gfx/shader_glsl.c:471: undefined reference to `glDeleteShader'
/home/pi/RetroArch/gfx/shader_glsl.c:475: undefined reference to `glUseProgram'
gfx/shader_glsl.o: In function `get_uniform':
/home/pi/RetroArch/gfx/shader_glsl.c:254: undefined reference to `glGetUniformLocation'
/home/pi/RetroArch/gfx/shader_glsl.c:477: undefined reference to `glUniform1i'
/home/pi/RetroArch/gfx/shader_glsl.c:478: undefined reference to `glUseProgram'
/home/pi/RetroArch/gfx/shader_glsl.c:261: undefined reference to `glGetUniformLocation'
/home/pi/RetroArch/gfx/shader_glsl.c:473: undefined reference to `glDeleteShader'
gfx/shader_glsl.o: In function `get_attrib':
/home/pi/RetroArch/gfx/shader_glsl.c:274: undefined reference to `glGetUniformLocation'
/home/pi/RetroArch/gfx/shader_glsl.c:281: undefined reference to `glGetAttribLocation'
gfx/shader_glsl.o:/home/pi/RetroArch/gfx/shader_glsl.c:261: more undefined references to `glGetUniformLocation' follow
gfx/shader_glsl.o: In function `find_uniforms':
/home/pi/RetroArch/gfx/shader_glsl.c:603: undefined reference to `glUseProgram'
gfx/shader_glsl.o:/home/pi/RetroArch/gfx/shader_glsl.c:254: more undefined references to `glGetUniformLocation' follow
/home/pi/RetroArch/gfx/shader_glsl.c:651: undefined reference to `glUseProgram'
gfx/shader_glsl.o:/home/pi/RetroArch/gfx/shader_glsl.c:281: more undefined references to `glGetAttribLocation' follow
gfx/shader_glsl.o: In function `gl_glsl_init':
/home/pi/RetroArch/gfx/shader_glsl.c:863: undefined reference to `glGenBuffers'
/home/pi/RetroArch/gfx/shader_glsl.c:864: undefined reference to `glGenBuffers'
gfx/shader_glsl.o:/home/pi/RetroArch/gfx/shader_glsl.c:864: more undefined references to `glGenBuffers' follow
gfx/shader_glsl.o: In function `load_luts':
/home/pi/RetroArch/gfx/shader_glsl.c:295: undefined reference to `glGenTextures'
/home/pi/RetroArch/gfx/shader_glsl.c:320: undefined reference to `glTexImage2D'
/home/pi/RetroArch/gfx/shader_glsl.c:326: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:309: undefined reference to `glBindTexture'
/home/pi/RetroArch/gfx/shader_glsl.c:311: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/shader_glsl.c:312: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/shader_glsl.c:316: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/shader_glsl.c:317: undefined reference to `glTexParameteri'
/home/pi/RetroArch/gfx/shader_glsl.c:319: undefined reference to `glPixelStorei'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_GetRenderbufferParameteriv'
/opt/vc/lib/libEGL.so: undefined reference to `gl20_client_state_init'
/opt/vc/lib/libEGL.so: undefined reference to `gl11_client_state_init'
/opt/vc/lib/libEGL.so: undefined reference to `glintAttribPointer'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_GenFramebuffers'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_buffer_info_get'
/opt/vc/lib/libEGL.so: undefined reference to `glDiscardFramebufferEXT'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_FramebufferTexture2D'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_IsRenderbuffer'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_set_error'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_BindFramebuffer'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_GenRenderbuffers'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_set_error_api'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_BindRenderbuffer'
/opt/vc/lib/libEGL.so: undefined reference to `glBufferSubData'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_GetFramebufferAttachmentParameteriv'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_CheckFramebufferStatus'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_FramebufferRenderbuffer'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_RenderbufferStorage'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_DeleteRenderbuffers'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_GenerateMipmap'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_buffer_info_set'
/opt/vc/lib/libEGL.so: undefined reference to `glPointSizePointerOES'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_DeleteFramebuffers'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_IsFramebuffer'
/opt/vc/lib/libEGL.so: undefined reference to `glxx_client_state_free'
collect2: ld returned 1 exit status
make: *** [retroarch] Error 1
Thank you for your patience.
P.S. Is prBoom compatible with Heretic and Hexen?
by KitchUK » Tue Feb 11, 2014 8:54 pm
antiriad wrote:
Vanfanel wrote:...
LD retroarch
No it is not.
by antiriad » Tue Apr 08, 2014 11:24 am
following this tutorial I was able to compile Chocolate Doom on my rPi.
Chocolate Doom allows multiplayer on a dedicated server, so... do you think the RPI can be a good dedicated server for Chocolate Doom? What about performances?
Thank you very much!
by thewarrior943 » Sun Apr 20, 2014 10:15 am
everything worked up until i cant put my doom1.wad in its folder into usr/share because it wont let me :?:
by DougieLawson » Sun Apr 20, 2014 10:57 am
Prefix the command with sudo to use root privileges to copy to /usr/share
Please post technical questions on the forum, not by personal message. Thanks.
Hacker on ZX80, Microtan65, Raspberry Pi & Arduinos
Mainframe Database troubleshooter
MQTT Evangelist
RPi owner since 2012.
Twitter: @DougieLawson
2B, B+, A+, 5Bs, C
