Page flipping / Double buffering
by aaa801 » Tue Jan 15, 2013 10:14 pm
Has anyone managed to implement page flipping / double buffering in the bcm 2708 fb driver?
by -rst- » Fri Jan 25, 2013 12:09 pm
I took a stab at this a while ago - unfortunately I have no previous experience in kernel/driver development and did not get really anywhere with setting up the build environment - not enough time or not enough drive to take the time... :oops:
It definitely looks like doable using the mailbox iface 'Set virtual (buffer) width/height' and 'Set virtual offset'... Dom 'almost promised' to 'look into' it viewtopic.php?f=67&t=19073&p=231080#p231058 :roll:
(Guess everyone reading this sub-forum knows these already... https://github.com/raspberrypi/firmware ... -interface and https://github.com/raspberrypi/linux/bl ... m2708_fb.c)
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
by -rst- » Fri Apr 05, 2013 11:28 am
Some more info on this viewtopic.php?f=67&t=19073&p=324866#p324866 ...looks like this would be trivial and would be even vsync'ed 'for free'...
by cleverca22 » Sat Apr 13, 2013 6:14 am
(i havent checked the posts linked above)
from the testing ive done under android, the normal framebuffer calls to do page flipping appear to just work on the raspberrypi fork of android
(dumbed down example with no error checking)
ioctl(fd, FBIOGET_VSCREENINFO, &info); // get defaults from kernel (edid prefered?)
info.yres_virtual = info.yres * 2; // request a virtual framebuffer twice as tall
ioctl(fd, FBIOPUT_VSCREENINFO, &info); // store the changes back into kernel config
and then to flip pages
info.activate = FB_ACTIVATE_VBL; // apply at vsync maybe???
info.yoffset = offset; // set the offset to scroll to (scroll down by 1 screen-height to flip the pages)
ioctl(m->framebuffer->fd, FBIOPUT_VSCREENINFO,info); // inform the driver
