ALSA problems [SOLVED]
by thommy » Sun Mar 17, 2013 11:36 pm
I'm setting up MPD to stream music from my NAS to a USB sound card.
That bit was fairtly straightforward:
Install Raspbian
Install ALSA
Install MPD
mount network share at boot using fstab
configure MPD
...and for a few hours today I had the perfect audio streamer. Until I rebooted.
MPD can no longer open the audio device and so is stuck in 'Paused' mode.
Typing 'alsamixer' at the prompt gives "cannot open mixer: No such file or directory"
Typing 'aplay -l' gives:
"**** List of PLAYBACK Hardware Devices ****
card 1: Set [C-Media USB Headphone Set], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0"
both root and my own account are members of the 'audio' group
It's been 5 hours sf stress trying to work out what changed after the reboot and I'm now at a loss!
by ski522 » Mon Mar 18, 2013 11:16 am
[quote="thommy"]
Subdevices: 1/1
Subdevice #0: subdevice #0"[/quote]
This indicates that your card is set to device 1, therefore in your "/etc/mpd.conf" file do you have the following (or something similar)?
[code]# An example of an ALSA output:
audio_output {
type "alsa"
name "My ALSA Device"
device "hw:1,0" # optional
format "44100:16:2" # optional
mixer_device "default" # optional
mixer_control "PCM" # optional
mixer_index "0" # optional
[/code]
Specifically this line [quote]device "hw:1,0" # optional[/quote]
If you want to default your USB sound card to device 0 then "sudo nano /etc/modprobe.d/alsa-base.conf" and change the "options snd-usb-audio index=0", reboot.
by thommy » Mon Mar 18, 2013 11:30 am
Hi.
Thanks for taking the time to look at this. I have scoured the web and as yet found nothing relating directly to this issue.
Subdevices: 1/1
This shows that there is only 1 device, but that it's on hw:0,0
The problem isn't within MPD because the alsa mixer wont load and sound-test produces nothing.
When trying to play in MPD I get this:
mpc play
AFL - Smoke Sessions Vol. 16
[paused]  #1/24   0:00/55:08 (0%)
volume: n/a   repeat: off   random: off   single: off   consume: off
ERROR: problems opening audio device
When trying to load the alsamixer I get this:
alsamixer
I get these messages when logged into as both root and my user account.
I have checked alsa.conf settings but this now seems to be deprecated as devices are detected automatically.
by Cloudcentric » Mon Mar 18, 2013 6:14 pm
Sound output by default will by either HDMI or Audio Out Jack, and by default it will auto-detect,:
HDMI output:
sudo modprobe snd_bcm2835
sudo amixer cset numid=3 2
Audio Jack output:
sudo amixer cset numid=3 1
Autodetect output:
sudo amixer cset numid=3 0
http://blog.scphillips.com/2013/01/soun ... -with-alsa
I know everything about nothing"
by thommy » Mon Mar 18, 2013 6:26 pm
Thanks.
You seem to be suggesting that I buy another soundcard however this one works fine as proved on the afternoon after installation (and before reboot) when i was playing a variety of hi res audio files.
It's being detected as hw:0,0 i.e. default (because i haven't added the sound drivers for the pi onboard audio). Therefore the link you provide is not helpful because it states in the first few paragraphs to look elsewhere if using a USB audio device.
The modprobe commands do not help either because I am not trying to use either of the onboard audio devices and my post shows that when trying to run alsamixer i get the error 'No such file or directory' - which suggests it is a permissions issue (but I don't know that).
by ski522 » Mon Mar 18, 2013 6:31 pm
No..."card 1" would indicate that it's card 1 not card 0 so it would "hw:1.0...for example here is what mine shows for aplay -l
card 0: DAC [USB Audio DAC], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 1: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
Also, I find it odd that aplay -l isn't show the bcm2835 on-board sound card. Did you make the change in alsa-base.conf file I suggested? Not sure what you mean when you say you didn't load the onboard sound card drivers, did you remove them?
What happens when you run alsamixer -c 1 #for hw:1.0
by Cloudcentric » Mon Mar 18, 2013 6:56 pm
USB Sound Card
use Nano text editor to open alsa-base.conf, place a # in front of options snd-usb-audio index=-2
sudo reboot
http://www.jackenhack.com/raspberry-pi- ... y-problems
by ski522 » Mon Mar 18, 2013 8:40 pm
Cloudcentric wrote:USB Sound Card
sudo reboot
No, the OP wants the USB sound card to be default or index 0, you instructions would make always default to index 1.
by Cloudcentric » Mon Mar 18, 2013 8:45 pm
Yep I missed a line out...............
The trick to make the card work is to edit the file /etc/modprobe.d/alsa-base.conf and comment out the line:
with
#options snd-usb-audio index=-2
and add this line at the end.
options snd-usb-audio nrpacks=1
This forces the USB device to become the default audio output device. The added line removes a lot of debugging info getting written to the syslog file, filling it up with lines like these.................................................................
by thommy » Mon Mar 18, 2013 9:29 pm
Thanks guys, it's working now.
