Change rainbow splash screen??
by redhawk » Fri Dec 07, 2012 3:04 pm
When the PI boots up a rainbow coloured squire appears at the start, is it possible to change this image to something else and if so how??
Richard S.
by dom » Fri Dec 07, 2012 3:40 pm
You can change it to a black square:
disable_splash=1
in config.txt....
You could then display your desired splash screen earliy in the linux boot (which is what OpenELEC/Raspbmc do).
by redhawk » Sat Dec 08, 2012 1:12 am
Thanks for the tip however I would rather replace the image than disable it.
What's the procedure for changing the splash screen does it have to be a specific format or resolution??
Richard S.
by daveg » Sat Dec 08, 2012 9:50 am
I don't think you will be able to change it as it is a test image which displays before the gpu starts loading the OS and is probably embedded in the SoC or coded into the gpu blob which isn't for public editing.
by mahjongg » Sat Dec 08, 2012 10:01 am
Its not a splash screen, its a test the GPU does, before linux even boots. You have the choice of disabling it.
by dom » Sat Dec 08, 2012 12:53 pm
It's actually a four pixels zoomed up to fill the screen. The rainbow effect comes from the scaling kernel.
by point » Tue Oct 08, 2013 6:15 pm
The disable_splash=1 in config.txt does not have any influence. I'm running the latest firmware and kernel on RPi B 512 MB version.
What could be the cause?
by qubodup » Tue Sep 16, 2014 5:16 pm
Adding
disable_splash=1
to /boot/config.txt should do it as described on http://www.raspberrypi.org/documentatio ... fig-txt.md
disable_splash
If set to 1, don't show the rainbow splash screen on boot. The default value is 0.
However this has no effect in NOOBS raspberrypi 3.12.28+ on RPi B.
