rpi-update
by bfromcolo » Fri Aug 17, 2012 6:52 pm
How do get rpi-update installed and working in Raspian? I get command not found. apt-get install does not find it.
by SirLagz » Fri Aug 17, 2012 7:05 pm
In the latest raspbian, they have changed the package name.
Look for raspberrypi-bootloader - That is the somewhat more stable package.
If you want cutting edge, you will need the rpi-update script, which you can get at https://github.com/Hexxeh/rpi-update/blob/master/rpi-update
by bfromcolo » Fri Aug 17, 2012 7:52 pm
Thanks for responding. I was hoping a more recent firmware update would help with issues with network when using USB hubs that are well documented in other threads. It does appear that raspberrypi-bootloader is installed, since apt-get tells me its at the latest version. When I try to execute it I get command not found. find and whereis are not telling me where to look, and its not in /usr/bin like rpi-config would have been. My Linux experience has been limited to playing around Ubuntu, I would appreciate any help if I am going about this the wrong way.
by MakerDyne » Fri Aug 17, 2012 10:29 pm
The package raspberrypi-bootloader isn't a program to fetch the latest firmware. The package itself is the latest (stable) firmware. To make sure that you've got the latest version provided by it, use aptitude to update it: run
sudo aptitude update && sudo aptitude full-upgrade
by bfromcolo » Fri Aug 17, 2012 10:44 pm
OK so when it ran and said it was at the latest version that actually meant my firmware was at the latest "official" version.
I managed to get rpi-update working following instruction on the WIKI trouble shooting page. That did install a newer version of firmware, but still has not resolved the problems with my USB hub and WIFI adapter.
