Slingbox on Pi
by XtR » Sat Jul 21, 2012 12:45 pm
Can i run slingbox web client on Raspberry Pi?
by ndoren » Sat Jul 21, 2012 4:48 pm
Unfortunately, it requires flash.
by XtR » Sat Jul 21, 2012 6:18 pm
Thanks for the answer. Flash is not going to be supported?
I thought it uses another plugin...
Can i run slingplayer windows client through wine then?
by JeremyF » Sat Jul 21, 2012 6:32 pm
XtR wrote:Thanks for the answer. Flash is not going to be supported?
I'm not sure what the online client is built in, but the video is in VC-1, not H.264 or Xvid, so it can't be used anyway.
Also Wine does not run on ARM.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
by XtR » Sat Jul 21, 2012 6:34 pm
So i have to forget this use for my rpi... :(
Thanks for your answers!
Edit: Slingbox pro hd streams in h264...
by JeremyF » Sat Jul 21, 2012 7:12 pm
XtR wrote:So i have to forget this use for my rpi... :(
It does? hmm...
by XtR » Sat Jul 21, 2012 7:16 pm
:) Any ideas????
by JeremyF » Sat Jul 21, 2012 8:14 pm
XtR wrote::) Any ideas????
Maybe there is an XBMC addon that will read the Slingbox HD stream?
by XtR » Sat Jul 21, 2012 8:20 pm
There is but it only reads the slingbox solo streams not slingbox's PRO HD...
So i think i ll have to wait and hope. ;)
by rickyhong » Wed Aug 22, 2012 7:27 pm
by JeremyF » Sun Aug 26, 2012 12:37 am
Can't you buy a VC-1 license now?
by ghans » Sun Aug 26, 2012 7:11 am
Yes.
Wine doesn't work and won't work on a Pi. WINE Is Not an Emulator , therefore only provides API hooks.
It needs a x86 , but the Pi is ARM.
ghans
by sdrider » Sun Apr 28, 2013 12:04 am
Last update on this topic was over a year ago, where there was some hope XBMC might be able to decode Slingbox HD Pro.. anyone had any luck with this? I'm trying to build a low-cost media device for two TVs in my house. With XBMC on Pi and my Plex server, it seems I have everything covered except my Slingbox. :(
I'm hoping maybe some progress has been made in the last year and the magic bits might be there to get a sling feed on my Pi. Any news or success stories would be great!
by ghans » Sun Apr 28, 2013 3:35 pm
You can always try hacking with rtmpdump and omxplayer , because
Flash will never work on the Pi :
viewtopic.php?f=63&t=40501
ghans
