sdb1 changing to sdc1
by P3ter » Sat Nov 24, 2012 12:03 am
I used two hard disks with my Raspberry Pi through USB. After the boot I have my two HDD like this :
/dev/sda1
/dev/sdb1
But after few minutes I have :
/dev/sda1 (OK)
/dev/sdc1 (WTF ?)
Twitter : @p3terdickins0n
Blog : p3ter.fr
by sander2 » Sat Nov 24, 2012 1:10 pm
Anything reported by dmesg?
by P3ter » Mon Nov 26, 2012 1:49 pm
I try with just one disk and I have the same problem (sda1 changing to sdb1). It appears randomly when I try to create LVM logical volumes.
$ dmesg | grep sda
[    5.514736] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[    5.550317] sd 0:0:0:0: [sda] Write Protect is off
[    5.562820] sd 0:0:0:0: [sda] Mode Sense: 38 00 00 00
[    5.570100] sd 0:0:0:0: [sda] No Caching mode page present
[    5.584838] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    5.827257] sd 0:0:0:0: [sda] No Caching mode page present
[    5.842842] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.270565]  sda: sda1
[    7.308440] sd 0:0:0:0: [sda] No Caching mode page present
[    7.323746] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.341296] sd 0:0:0:0: [sda] Attached SCSI disk
[  135.693871] scsi 0:0:0:0: [sda] killing request
[  135.694210] scsi 0:0:0:0: [sda] Unhandled error code
[  135.694232] scsi 0:0:0:0: [sda]  Result: hostbyte=0x01 driverbyte=0x00
[  135.694254] scsi 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 25 42 ea a0 00 00 08 00
[  135.694297] end_request: I/O error, dev sda, sector 625142432
I need to reboot to have /dev/sda1.
sudo lvdisplay
  /dev/vgraspiprive/lvbackup_server: read failed after 0 of 4096 at 107374116864: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_server: read failed after 0 of 4096 at 107374174208: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_server: read failed after 0 of 4096 at 0: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_server: read failed after 0 of 4096 at 4096: Erreur d'entrée/sortie
  /dev/sda1: stat failed: Aucun fichier ou dossier de ce type
  Path /dev/sda1 no longer valid for device(8,1)
  /dev/disk/by-id/usb-ST320LM0_01_HN-M320MBB_FF320FF001F2F6F9DC90693-0:0-part1: stat failed: Aucun fichier ou dossier de ce type
  Path /dev/disk/by-id/usb-ST320LM0_01_HN-M320MBB_FF320FF001F2F6F9DC90693-0:0-part1 no longer valid for device(8,1)
  /dev/disk/by-path/platform-bcm2708_usb-usb-0:1.3.2.4:1.0-scsi-0:0:0:0-part1: stat failed: Aucun fichier ou dossier de ce type
  Path /dev/disk/by-path/platform-bcm2708_usb-usb-0:1.3.2.4:1.0-scsi-0:0:0:0-part1 no longer valid for device(8,1)
  /dev/vgraspiprive/lvbackup_filer: read failed after 0 of 4096 at 107374116864: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_filer: read failed after 0 of 4096 at 107374174208: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_filer: read failed after 0 of 4096 at 0: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_filer: read failed after 0 of 4096 at 4096: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_repos: read failed after 0 of 4096 at 10737352704: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_repos: read failed after 0 of 4096 at 10737410048: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_repos: read failed after 0 of 4096 at 0: Erreur d'entrée/sortie
  /dev/vgraspiprive/lvbackup_repos: read failed after 0 of 4096 at 4096: Erreur d'entrée/sortie
  Volume group "vgraspiprive" not found
  Skipping volume group vgraspiprive
Blog : p3ter.fr
by fbrassin » Wed Feb 20, 2013 7:55 am
This is happening also to me.
I have an external hdd connected through autoalimented usb hub.
It is /dev/sda1, when i run transmission and start a torrent after few seconds hdd disappeares and with fdisk -l
i don't see anymore /dev/sda1 but /dev/sdb1.
It seems as the hdd disconnect and reconnect to new point.
Any idea on how to solve?
