Firmware
by truehl » Sun Nov 04, 2012 9:32 am
Does Debian SoftFloat use the same firmware in /boot as the HardFloat version? And the same question for /lib/firmware: Can Debian SoftFloat also use this firmware for e.g. the WiFi adapters?
truehl
http://www.squeezeplug.de
by truehl » Thu Nov 08, 2012 7:10 am
I thought this was a very simple question! Is no one able to answer?
truehl
by sander2 » Thu Nov 08, 2012 5:20 pm
Maybe you're able to answer the question yourself: create a SD-card with the soft-float image, and then a SD-card with the hard-float image, and compare what you want to compare.
Remember: one of the great things of the Raspi, is that you can freely experiment and tinker with it.
HTH
by truehl » Thu Nov 08, 2012 6:35 pm
Thanks for the hint, I hoped there was a much quicker way! :(
truehl
by tufty » Thu Nov 08, 2012 7:23 pm
Part of the problem is that your question is very badly worded.
The 'firmware' files, used by the GPU, are the same. Everything else (kernel etc) has to be compiled for hardfloat/softfloat.
