Yep - another cheap touchscreen question..
by Alfadaz » Thu Jun 28, 2012 4:38 pm
Would this cheap 3.2" Touchscreen TFT LCD Module Display interface with the Raspi using the GPIO (or any other source)?
The Spec sheets and code can be found in my dropbox folder HERE
EBAY LINK
Cheers
Daz
by ceteras » Wed Jul 04, 2012 9:13 am
It seems you need a lot of IO pins for this display, as just the data bus is 16bit.
I would try the MCP23S17 from microchip, an SPI port expander, you can connect several (up to 8) on the SPI bus, then modify the software to use the SPI bus.
by TommyboyNL » Wed Jul 04, 2012 11:18 am
Or just buy a $20 640x480 composite LCD from eBay...
