Photo keyring as screen
145 posts   Page 2 of 6   1, 2, 3, 4, 5, 6
by ax206geek » Wed Jun 27, 2012 1:44 pm
@meltwater
ax206term is just a terminal console. The other ported programs can be found here. The dpf-ax SVN comes with a sample lcd4linux conf file and the build script should work too. I'll be trying lcd4linux out on my R-Pi soon. lcd4linux can certainly display images and pydpf would too.
by meltwater » Wed Jun 27, 2012 1:49 pm
ax206geek wrote:@meltwater
Thanks very much! I'll have a go and see how I get on.
______________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
My new book: goo.gl/dmVtsc
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
by funny » Wed Jun 27, 2012 3:46 pm
meltwater wrote:Thanks to some help from doozan.com I now have a hacked picture frame.
http://forum.doozan.com/read.php?2,2435 ... 9#msg-8330
Hopefully that will also help you out. Happy to give more details if needed.
Now comes the small task of trying to work out how to use lcd4linux... :shock:
cud u plz give that ebay link to buy these kinda frames!!
by meltwater » Wed Jun 27, 2012 10:35 pm
It was posted above...
http://www.dealextreme.com/p/1-5-lcd-re ... rage-27893
Mine was from dealextreme.com, but be warned they can change stock. It works with Ax206term, yet to try the others though.
______________
by ashbash » Thu Jun 28, 2012 6:36 am
@ meltwater, ax206geek - Thanks, will check out dealextreme :)
by clickykbd » Thu Jun 28, 2012 7:20 am
This is one neat little trick. Too bad the larger photo frames tend to run off memory cards instead of direct USB transfers to internal memory. *clicks the "watch thread" button*
by ax206geek » Thu Jun 28, 2012 1:31 pm
clickykbd wrote:Too bad the larger photo frames tend to run off memory cards instead of direct USB transfers to internal memory.
Going slightly off-topic here, but some Samsung frames - the larger frames can do these:
http://web.media.mit.edu/%7Egracewoo/stuff/picframe/
http://pyframe.blogspot.sg/2011/12/usin ... or_16.html
http://www.puschmann.net/page/?page_id=62
by kontextbewusst » Fri Jun 29, 2012 9:26 am
Nice work with the ax206term! Did anyone of you get the DPF working with lcd4linux on the RPi? I successfully flashed my DPF (it's the China Version, dx21334b). However, with the example config from dpf-ax, lcd4linux cannot find the DPF:
$ ./lcd4linux -f ../dpf.conf -F
Found AX206 DPF
Got LCD dimensions: 0x0
dpf: cannot open dpf device usb0
Error initializing driver DPF: Exit!
My guess is that the port identifier is different on the RPi, i already tried usb, or usbdev1.4 (which is the the port reported by dmesg).
Can anyone help me? I'll try the st2205term/ax206term now, already compiling...
Best,
Max.
by kontextbewusst » Fri Jun 29, 2012 10:59 am
Shame on me... of course lcd4linux needs to run with sudo. It's working now :)
by clickykbd » Fri Jun 29, 2012 11:31 am
wonder what it would take to get them to make a raspberry shaped one:
http://www.dealextreme.com/p/1-5-lcd-he ... 32?item=14
(edited to the 1.5" display heart shaped one, more raspberry approximate already)
That one is so close, a little sharpie details and some glued on leaves and you are there.
by funny » Fri Jun 29, 2012 11:35 am
clickykbd wrote:wonder what it would take to get them to make a raspberry shaped one:
http://www.dealextreme.com/p/1-1-inch-h ... 515?item=2
nice idea!
by kontextbewusst » Fri Jun 29, 2012 11:40 am
funny, I cannot send PMs yet (started posting here today) -- I bought this display from eBay (Germany in my case, but it's an international seller):
http://www.ebay.de/itm/260978964426?ssP ... 1439.l2649
by clickykbd » Fri Jun 29, 2012 11:49 am
funny wrote:nice idea!
Alas, too nice/tempting. Ordered one on the off chance it's a supported model.
by gabychan » Sat Jun 30, 2012 11:45 am
kontextbewusst wrote:Shame on me... of course lcd4linux needs to run with sudo. It's working now :)
Hello, can explain how you installed the LCD in the RPI?
You can do a How to, what I have with the Firm_21334a of Superelchi, but when compiling in Raspberry does not work. I have the same error as above you.
regards
by ax206geek » Sat Jun 30, 2012 2:27 pm
gabychan wrote:Hello, can explain how you installed the LCD in the RPI?
regards
I can try to help. Do you have errors with compiling lcd4linux or with permissions
If it is compiling errors, just make sure the dependencies are sorted out, this is IIRC
sudo apt-get install autoconf libtool libusb-dev python2.6-dev
then build-dpf-lcd4linux.sh should execute smoothly.
The permission error was solved with sudo but lcd4linux will also complain on the permissions of dpf.conf so if this is done from lcd4linux directory inside dpf-ax directory
chmod g-r-x,o-r-x ../dpf.conf
should sort things out
by gabychan » Sat Jun 30, 2012 7:07 pm
Thank you so much
This is what I get on the console
Which drivers to compile checking ... done
configure: WARNING: dpf.h not found: DPF driver disabled
configure: error: You should activate at least one driver ...
make: *** No no target specified and no makefile found any. Alto.
@ raspberrypi ~ pi / dpf-ax $
by ax206geek » Sun Jul 01, 2012 1:27 am
gabychan wrote:This is what I get on the console
Try copying libdpf.so to /usr/local/lib. I've also uploaded my lcd4linux folder with compiled binary from my Pi to here
by gabychan » Sun Jul 01, 2012 1:51 pm
This is the error after installing the dependencies
pi@raspberrypi:~/dpf-ax$
pi@raspberrypi:~/dpf-ax$./build-dpf-lcd4linux.sh
/usr/bin/ld: cannot find -ldpf
collect2: ld returned 1 exit status
make[1]: *** [lcd4linux] Error 1
make[1]: se sale del directorio `/home/pi/dpf-ax/lcd4linux'
make: *** [all] Error 2
by ax206geek » Mon Jul 02, 2012 12:12 pm
gabychan wrote:This is the error after installing the dependencies
Assuming libdpf.so is in /usr/local/lib, try this
ldconfig /usr/local/lib
by gabychan » Mon Jul 02, 2012 2:13 pm
ax206geek wrote:Assuming libdpf.so is in /usr/local/lib, try this
No I do not find on any side libdpf.so.
Sorry not to do more.
Thanks for your help
by ax206geek » Mon Jul 02, 2012 2:25 pm
@gabychan
You were supposed to compile dpf-ax to obtain libdpf.so which is in the Debug folder of dpf-ax. Anyway here's my copy
by gabychan » Mon Jul 02, 2012 3:45 pm
Thanks,
My orders
# sudo rm -rf dpf-ax
# sudo svn co https://dpf-ax.svn.sourceforge.net/svnroot/dpf-ax/trunk dpf-ax
# cd dpf-ax
# sudo cp your_libdpf.so /usr/local/lib
# sudo chmod 755 dpf.conf
# sudo ./build-dpf-lcd4linux.sh
# cd lcd4linux
# sudo make
#pi@raspberrypi:~/dpf-ax/lcd4linux$ sudo make
make  all-am
make[1]: se ingresa al directorio `/home/pi/dpf-ax/lcd4linux'
pi@raspberrypi:~/dpf-ax/lcd4linux$ sudo lcd4linux -l
lcd4linux: error while loading shared libraries: libdpf.so: cannot open shared object file: No such file or directory
pi@raspberrypi:~/dpf-ax/lcd4linux$ sudo lcd4linux -Fvv
by gabychan » Mon Jul 02, 2012 5:58 pm
SOLVED
ax206geek wrote:@gabychan
It seems that this fixed
Many thanks again
^Clcd4linux.c: got signal 2
lcd4linux.c: leaving main loop
DPF: shutting down.
drv_dpf.c: closing connection
pi@raspberrypi:~$
by basst85 » Tue Jul 03, 2012 9:15 am
I have this photo keyring:
And want to write a image to it every x seconds, but dont know how to write to te correct sector on the chip. And dont know where to start :)
dmesg give me this info:
[  121.103956] usb 1-1.2: new full speed USB device number 5 using dwc_otg
[  121.363980] usb 1-1.2: new full speed USB device number 6 using dwc_otg
[  121.465356] usb 1-1.2: config 1 has an invalid descriptor of length 44, skipping remainder of the config
[  121.466350] usb 1-1.2: New USB device found, idVendor=18b6, idProduct=1201
[  121.466379] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[  121.466400] usb 1-1.2: Product: MOS003-USB ALBUM
[  121.482424] scsi0 : usb-storage 1-1.2:1.0
[  122.485637] scsi 0:0:0:0: CD-ROM            MKU007-  USB PHOTO ALBUM  1.00 PQ: 0 ANSI: 2
[  122.534992] sr0: scsi3-mmc drive: 0x/0x caddy
[  122.535027] cdrom: Uniform CD-ROM driver Revision: 3.20
[  122.539917] sr 0:0:0:0: Attached scsi CD-ROM sr0
[  122.574855] sr0: Hmm, seems the drive doesn't support multisession CD's
And lsusb:
Bus 001 Device 007: ID 18b6:1201 Mikkon Technology Limited
\dev\sr0 only contains a program for Windows.
by Gabriel » Tue Jul 03, 2012 12:11 pm
If it can help somebody, I already launched a subject about this in august (a long time ago ^^) :
viewtopic.php?f=46&t=428
Don't know if it may help but I had the hack working on a cheap asian NAS (so ARM hardware...).
In the last answers the subject was changing to "working lcd screens".
At least it will help google ;) .
Should I link this topic in a reply of the previous topic ? [which should be closed then]
Gabriel
ps : I'm going to use the screen of a "coby dp-152 keychain digital photo frame" in this project : viewtopic.php?f=35&t=7739 and I will add pictures soon.
My home-made case : http://goo.gl/nprcI ; My presentation http://goo.gl/5hSar et en français : http://goo.gl/28Vif ; Please think to the FAQ and to the Wiki
