Composite Screen Questions
by e*pi » Fri Oct 26, 2012 8:30 pm
I have some questions which probably everybody faces who thinks about getting an small LCD for his RPi.
What ist the maximum resolution which can go out over Composite?
I am looking for a screen between 3.5" and 7".
There is this one 3.5"-Display which every second person seems to get for his RPi.
But which resolution does it have?
I found different claims about that, but I believe they all are the same display and at least most of them have to be wrong:
960x468
http://www.amazon.com/3-5-Inch-TFT-Moni ... spberry+pi
960x240
http://www.ebay.com/itm/3-5-Inch-Color- ... 3ccb76ad26
320x234
http://www.ebay.com/itm/Mini-3-5-TFT-LC ... 3cc88fa32d
640x480
http://www.ebay.com/itm/NEW-3-5-TFT-LCD ... 1e712b465f
That left me pretty confused. I mean 640x480 would just be great for such a small display if it was true.
I will be more than happy if somebody can give mit an advice on that. I would actually go up to 7" if it has a reasonable price, and not to crappy resolution.
Thanks to all of you and enjoy your pies.
by JeremyF » Sat Oct 27, 2012 12:32 am
I can say with great certainty that the maximum resolution of any of these screens is 640x480, for some it may be less.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
by Fray Bentos » Fri Nov 02, 2012 2:49 pm
Im using composite as I type, and the resolution is 656X416. I cannot change the resolution as there is only one option. You can find out what resolution you are running at (in Raspbian Wheezy) by going to File Manager--> Applications-->Preferences-->Desktop Settings--> Monitor Settings ( menu://applications/DesktopSettings .).
You might be able to mess around with settings in the config file (you can this by plugging your SD card into a card reader on a PC/Mac and going to the config file).
Have a look at elinux.org
