Why does my Pi stop running services or programs?
by Alligator » Fri Jan 25, 2013 10:05 pm
I set up a python script to run at startup by placing it in the init.d folder. I registered it, and it starts when the Pi boots. It will run for anywhere from 5 minutes to 10 minutes, then stops. How can I figure out why, and how can I make sure it keeps running (other than a crontab job starting every five minutes)?
by efflandt » Sat Jan 26, 2013 3:24 am
Why not redirect stdout and stderr to a log file, so you can see if an error tells you why it failed (as long as your script does not hide errors it traps). This is a simple demo. In reality you should probably have a full path to the script and location of log file. And if running other than root, the log file should be somewhere that user has permission to write to.
Simple test script that loops outputting date:
#!/bin/sh
while true; do date; sleep 10; done
Redirection example forked into background with output and errors appended to log file:
efflandt@XPS8100-1204:~$ dtest >> ~/dtest.log 2>&1 &
[1] 4865
efflandt@XPS8100-1204:~$ fg
^C
efflandt@XPS8100-1204:~$ cat ~/dtest.log
Fri Jan 25 21:13:37 CST 2013
Fri Jan 25 21:13:47 CST 2013
Fri Jan 25 21:13:57 CST 2013
Fri Jan 25 21:14:07 CST 2013
When error was inserted and run the same way, the error went to log file:
efflandt@XPS8100-1204:~$ cat bin/dtest
#!/bin/sh
while true; do date; sleep 10; what; done
efflandt@XPS8100-1204:~$ cat dtest.log
Fri Jan 25 21:27:28 CST 2013
/home/efflandt/bin/dtest: 2: /home/efflandt/bin/dtest: what: not found
Fri Jan 25 21:27:38 CST 2013
