3D Camera Board for Pi
by gladoscc » Thu May 24, 2012 12:07 am
I saw the add-on camera board, but it would be cool if there were two cameras, so it can take 3D pictures.. even if you could just buy 2 camera boards, it has the be a constant distance apart.
by jbeale » Thu May 24, 2012 12:26 am
No doubt there is a "cool" factor to 3D cameras, but they are still a tiny fraction of the camera market. Given that they are apparently only able to offer one type of camera, and want to keep the price to a minimum, and want the widest range of applicability it seems to me a basic 2D camera will be chosen.
by jamesh » Thu May 24, 2012 1:23 am
Although the GPU can support two cameras at the same time, the Raspi board only exports one CSI interface to the connector. So 3D isn't possible as standard.
Volunteer at the Raspberry Pi Foundation, helper at Picademy September, October, November 2014.
by JeremyF » Thu May 24, 2012 1:29 am
Don't listen to me at all, but:
MIPI CSI-2 has amazing bandwith, and the VideoCore IV is blisteringly fast when accelerated with appropriate drivers. Would it not be possible to run two cameras through one port?
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
by Gert van Loo » Fri May 25, 2012 9:35 am
JeremyF wrote:Don't listen to me at all, but:
Yes, you could.
You would need to use a CSI multiplexer chip like the FSA 642 from Fairchild.
But you would also need to tweak the drivers to have one camera running at a time which requires access to the GPU code.
by Pikachu47 » Wed May 30, 2012 11:59 am
If the camera is 14MP (i'm sure that's right isn't it) then you could see if a lens splitter was available. Panasonic make one for their 2d hd video cameras http://cdn.itproportal.com/photos/pan-3 ... inline.jpg .
You'd still end up with 7MP (ish) per eye, plenty for video and photos and you'd only need the one connector.
by wallarug » Sun Apr 06, 2014 7:00 am
Camera is 5MP
RPi Hardware Guide
App Store: https://itunes.apple.com/us/app/rpi-hardware-guide/id723108328?ls=1&mt=8
Play Store: https://play.google.com/store/apps/details?id=org.cmdenterprises.rpihardwareguide
http://www.youtube.com/user/CMDenterprises
by delicious_pi » Tue Jul 08, 2014 9:00 am
Two Words: Compute Module
by ShiftPlusOne » Tue Jul 08, 2014 9:48 am
The firmware doesn't properly support multiple cameras right now (or even one, on the compute module). Although changing it to be able to use both cameras at once isn't hard, doing so properly would take a while. But yeah, you should be able to use the compute module to access both cameras at the same time (eventually), but I don't know how practical it will be for 3D video.
