PI Heatsinks Wanted.
by christianwls » Fri Oct 05, 2012 9:50 pm
Any heatsink for any chip wanted. Preferably easy to fit (thermal pads), Also it must fit into an adverage size case. Thanks :)
RPI Model b.
HDMI
Ethernet.
Powered 4 USB port.
23" Monitor.
Keyboard & Mouse.
Wheezy (mainly used).
by nhslzt » Mon Oct 08, 2012 1:50 pm
by RaTTuS » Mon Oct 08, 2012 1:53 pm
any RAM chips ones will do - why are you sure you need them ?
http://www.catb.org/esr/faqs/smart-questions.html Ask Questions
http://www.raspberrypi.org/forums/viewtopic.php?f=29&t=7192 AutoStart Script
"That's not right, the badgers have moved the goalposts."
by Jonnyw2k » Thu Oct 18, 2012 7:20 pm
https://www.modmypi.com/shop/raspberry- ... t-sink-kit
I just want them as I think they look cool
by GSpratt » Tue Oct 23, 2012 8:02 pm
I have a heat sink that I salvaged from a PC. It will need cutting into smaller pieces, and thermal pads. Don't tknow what case you are looking at, but the sink is 12mm high so would stand the same height as the top of the LAN socket.
G
by woopderson » Wed Oct 24, 2012 12:42 pm
christianwls wrote:Any heatsink for any chip wanted. Preferably easy to fit (thermal pads), Also it must fit into an adverage size case. Thanks :)
I picked up a package fo these:
http://www.newegg.ca/Product/Product.as ... 6835708012
But they have been discontinued :|
by smartpatrol » Sun Oct 28, 2012 7:48 pm
Also any kit that is designed to fit Video card memory chips work perfectly such as the zerotherm zh100.
by furyfire » Wed Apr 17, 2013 6:37 am
Bit late -
I bought these - 8 peices for $2.40
They are only slightly bigger than the CPU and looks perfect installed
Aluminum Cooler Heat Sink Chipset for RAM Memory - W Type
Need accessories?
Checkout my verified list of cheap DX.com accessories.
http://furyfi.re/raspberrypi/accessories.pdf
