'Nokia 3310' type LCD add on board
102 posts   Page 3 of 5   1, 2, 3, 4, 5
by asa_g » Wed Jan 09, 2013 8:39 pm
How can i add ° character to the lcd font?
by texy » Wed Jan 09, 2013 9:28 pm
"2.8inch TFT LCD + Touch screen" add-on boards for sale here :
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=93&t=65566
50p goes to the Foundation ;-)
by texy » Sun Jan 20, 2013 10:05 am
Hi folks,
there have been some code changes and vaste speed improvements by utilising the hardware SPI function by forum member bgreat.
Nokia Pi LCD modules shipped from now on will be modified to make use of these improvements. See the python thread from this post onwards :
viewtopic.php?f=32&t=9814&start=100#p261343
Cheers,
Texy
by gsinghal » Tue Jan 22, 2013 5:57 pm
Hi, do you still have any left?
by texy » Tue Jan 22, 2013 7:58 pm
Yes. I do. Please pm me for details.
Texy
by sportsnapper » Tue Jan 22, 2013 8:08 pm
Texy, though I've read the thread, not sure what the mods are to your board (as I'd like to do them to the board I already have). Can you be a bit more specific??
by texy » Tue Jan 22, 2013 8:47 pm
Hi sportsnapper,
yeah - no problem.
There are three lines that need to change.
Currently they are wired thus :
LCD pin 2 = SCE = 2 # physical gpio pin 13
LCD pin 5 = SCLK = 5 # physical gpio pin 18
LCD pin 4 = DIN = 4 # physical gpio pin 16
To use the hardware SPI, they need to be changed to :
LCD pin 2 = SCE = 10 # physical gpio pin 24 = wiringpi no. 10 (CE0 BCM 8)
LCD pin 5 = SCLK = 14 # physical gpio pin 23 = wiringpi no. 14 (SCLK BCM 11)
LCD pin 4 = DIN = 12 # physical gpio pin 19 = wiringpi no. 12 (MOSI BCM 10)
You'll need to cut the existing tracks to all three lines to the LCD and add 3 new wires as above. I modified a bare pcb before fitting a LCD to modify it, so it was easier, but as yours will already have an LCD fitted, it may be a little more difficult to find suitable places to cut the tracks. If I get time later I will take photo's of the bare board and suggest suitable cutting places.
Hope this helps,
Texy
by sportsnapper » Tue Jan 22, 2013 8:51 pm
Thanks for the quick response texy, I'll get the board out later and check how I can do the changes.
by ColinD » Wed Jan 23, 2013 9:57 pm
Hi texy, where can I buy one from?
=C
Raspberry Pi articles and tutorials: www.rasptut.co.uk
by texy » Wed Jan 23, 2013 10:13 pm
From me ;-)
Texy
by Loloka » Fri Jan 25, 2013 7:26 am
Hi, Texy
do you still have any LCD left?
by texy » Fri Jan 25, 2013 8:10 am
Yes I do. Please pm me with your PayPal email and country. I will calculate postage.
Texy
by MartP » Sat Jan 26, 2013 10:49 pm
texy wrote:Hi,
I have for sale a number of PCB mounted, PDC8544 based, 'Nokia' type LCD's completely assembled and with a 26-way ribbon cable.
<snip>
Hi Texy,
Just joined the forum, so as soon as I can PM I'll be in touch for one of these. :D
I have a couple of old 3310 LCDs, but they are as you say, difficult to connect.
Good project, thnx.
Martin
by jsplace » Thu Jan 31, 2013 5:44 pm
Hi, do you have any of these left?
Many thanks
by texy » Thu Jan 31, 2013 10:52 pm
Yes I do, please pm me your details.
Cheers
Texy
by achapman » Fri Feb 01, 2013 3:29 pm
I've been playing with one of Texy's LCD's and been a bit puzzled by the contrast behaviour. I assumed from the comments in the various python scripts that the necessary contrast setting varied from LCD to LCD, so once you had figured out the correct value for your particular LCD unit, you shouldn't have to alter it.
What I found with mine though is that I got different results with the same screen between using it with one RPi and another. My late model Pi was optimised at 0xbf, but the same screen with an early model needed 0xa3 - quite a difference!
by texy » Fri Feb 01, 2013 3:42 pm
The figure is also temperature dependant, but I,ve seen so many now that I don't keep tabs. As you say though - they do tend to be around the range you mention.
Texy
by achapman » Fri Feb 01, 2013 4:01 pm
Texy, what's the situation with text display? Am I right in thinking there's no character set in firmware, the character set is just loaded in software. Your reply to asa_g has confused me as it refers to the 44780 LCD, which I believe does hold a character set in its firmware, whereas I thought the 3310 LCD is just a directly driven graphics display. All the scripts contain font data, so I assumed you had to supply the data for each character.
The examples in the test scripts are all 5x7 bitmapped fonts, has anyone got a script that displays any other font size?
by texy » Fri Feb 01, 2013 4:44 pm
yes you are correct on all points. I realised I gave bum info later, but I didn't get any reply from them.
As you say, the LCD is dumb and need to know the font details - I just goggled and found what I needed (as explained in the support thread in
the python forum). I think I did find some code for larger fonts, so there is something to be goggled.
Texy
by Jeroen1101 » Sun Feb 03, 2013 8:27 am
Hello texy
What it cost to ship 1 or 2 of this displays to the Netherlands?
by texy » Sun Feb 03, 2013 11:02 am
Hi Jeroen,
welcome to the forum. The cost to ship to the Netherlands will be £4.25. Even shipping 2 modules is less than 100gms, so price will be the same.
Cheers,
Texy
by Jeroen1101 » Sun Feb 03, 2013 8:24 pm
Ok how can we arrange it?
by texy » Sun Feb 03, 2013 8:47 pm
Send me a pm with your PayPal email address and I will send you an invoice.
Note also I have just released a shield type board - connects to the Pi without a cable :
viewtopic.php?f=59&t=32187
- it may be more suitable to your needs?
Regards
Texy
by MartP » Mon Feb 04, 2013 9:40 am
texy wrote:Hi,
<snip>
Regards
Texy
texy,
The new shield looks good - may have to have one of those as well as your earlier product :D
Martin
by MartP » Wed Feb 06, 2013 6:56 pm
MartP wrote:
texy wrote:Hi,
<snip>
Hi Texy,
Good project, thnx.
Martin
Texy,
Received my board on Tuesday of this week, and have had great fun " tinkering" with code samples from this forum. I am a complete beginner with Linux / python, and I had text in various fonts, bitmap pictures etc. all displaying on this little screen in no time at all :D If I can do it then any noob can! One thing; I had to alter the display contrast value to 0xb7 to get a picture - so if no picture is evident on yours, try that first. Our 11 year old Grandson is impressed with Graddad's efforts ;)
Thanks texy.
Martin
