[Bodhi Linux] Alpha Release
by JeffHoogland » Tue Jun 12, 2012 7:14 pm
I've got an early build of Bodhi ARM for the Pi uploaded - let me know what you think! http://jeffhoogland.blogspot.com/2012/0 ... e-for.html
~Jeff
by JeremyF » Tue Jun 12, 2012 11:27 pm
Haven't tested it yet, but I'm excited.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
by daka » Fri Jun 15, 2012 7:58 am
Early days but I am very happy with Bodhi on my Pi! I only had Debian installed before and Bodhi seems much quicker generally. I just seems a little slow or stubborn closing down or opening some windows. I have had Bodhi on my Desktop for almost a year and it works very well!
Daka
by Steep » Fri Jun 15, 2012 4:05 pm
Gave it a try today, it looks great and boot very quickly. Two problems though, I have no network connection (eth0 is recognised on on boot) and no network manager. The file system? is mounted read only so I can't alter the config files to try and get it working.
Any clues?
by daka » Fri Jun 15, 2012 10:05 pm
Hi
I also had those two problems and solved them easily. I will give you the link to the Bodhi Pi Forum where help for these and any other problems that you may encounter can be found:
http://forums.bodhilinux.com/index.php? ... pberry-pi/
The first topic provides a link to a blog announcing the Bodhi release fro the Pi. This page gives alternate user/passwords......
"The default logins for this image are:
bodhi/bodhi
root/raspberry
The "bodhi" user has sudo rights by default. "
I tried sudo leafpad using raspberry as the password and edited the appropriate file easily.
Let me know how you get on...or better still, connect with the Pi / Bodhi Forum where much more competent people can help you.
sean
by daka » Fri Jun 15, 2012 10:09 pm
.... Sorry...I wasn't clear.... the first topic gives a link to the announcement and this gives general info including passwords to solve that issue...the second topic relates to the network connection problem that you mentioned; I followed his suggestions to fix it.
sean
by Steep » Sat Jun 16, 2012 9:33 am
That did the trick, thanks. Odd though as the Pi sees the ethernet port as eth0 I had to change /etc/network/interfaces to eth1 to make it work.
by JeffHoogland » Wed Aug 08, 2012 3:58 pm
We've released a newer image, based on Bodhi's new ARMHF line (and raspbian).
http://jeffhoogland.blogspot.com/2012/0 ... armhf.html
http://www.bodhilinux.com/downloads_mobile.php
~Jeff
