OpenELEC
39 posts   Page 2 of 2   1, 2
by smuggly » Wed May 30, 2012 12:49 am
Thanks Alot I,ll report Progress Once Im Into It!
by Loumart78 » Thu May 31, 2012 3:14 am
viewtopic.php?f=4&t=5723
The file cannot be opened with zip.
by itimpi » Thu May 31, 2012 5:45 am
You probably need to use 7-zip (which is different to zip).
by BenvanDamme » Thu May 31, 2012 8:39 am
Playback starts fine but the whole system freezes after 20minutes of xvid playback. :(
by smuggly » Fri Jun 01, 2012 11:48 pm
OK I Got Mi Pi Up Playing 1080P from my windows home server. I'm using img 10710 Default. Samba is working great I,m using A Kingston 16GB SD Card 10 Class I Used Gparted to expand the storage partition. What I Would Like To Know Is? Is There A Better Kernel img. And Start.elf Than I'm Using? Thanks smuggly
It actually plays 1080p mkv files better than avi files ?
I'm using a iogear multimedia keyboard w/a trackball builtin it works great for this OS!
by smuggly » Sat Jun 02, 2012 12:39 am
Thought I Would Post More Of My Experiment! It Seems When Playing Hd Video Lg Files Act Like They're Buffering? It Takes Awhile To Get Going But, Once It Does It Plays Flawlessly. AVI Files Are Playing Great Also. The One I Tried B4 Was A Bad Encode! Smuggly
I set The Time Location Etc Samba Remembers My Network Info. Its Working Great...
by kubat » Thu Jun 14, 2012 9:06 pm
On OpenELEC I have this same problem with keyboard and mouse (as the ArchLinux) i can't input anything.
On Arch
I had the same problem but I created a new file in /etc/X11/xorg.d/10-xxxx.conf and put in the text:
Section "ServerFlags"
Option "AutoAddDevices" "False"
EndSection
solve the problem, but not here.
I mount a SYSTEM file from System partition, and create new file in /etc/X11/xorg.conf.d
named 10-new.conf
But it does not work, please help
by smuggly » Sat Jun 16, 2012 5:59 pm
I Had That Problem With A Low power Supply Try A Different One I Bet It Will Go Away... Smuggly
by kubat » Mon Jun 18, 2012 7:00 am
smuggly :mrgreen:
thank you very much, I used the charger 5.7V, 800mA (previously it did not pay attention) now I am using 5V and 700mA (that is, as given on the wiki), keyboard and mouse working. But still is not enough to connect hard drive 2.5''
by itimpi » Mon Jun 18, 2012 7:11 am
kubat wrote:smuggly :mrgreen:
You cannot connect a 2.5" HD directly to the Pi as it cannot provide enough power via its USB ports.. If you want to use a 2.5" HD you will need a powered Hub for the HD and that should have a 2A or better power adapter.
by diadem » Sat Jun 23, 2012 11:09 pm
Anyone created an image for beta 4 build? Im having compiler problems so cant compile it my self right now.
by diadem » Sun Jun 24, 2012 2:53 pm
Created an EC2 instance that Im going to use for compiling from now on. Apple are making things a little too difficult these days!
by Beimer » Mon Jun 25, 2012 3:28 pm
http://sparky0815.de/category/raspberry-pi-2/
nice blog with pre-compiled images of open elec for raspberry pi
by RicRPI » Fri Jul 13, 2012 7:12 am
Hi, thanks for sharing your build. Yesterday I installed and tested your build.
As you said the first boot took some time.
The menus lag a lot.
Looking up files from my 2 TB Netgear Nas disk worked fine. Except for the lag. But this might be the Nas disk at fault.
I also managed to get Teletube to work. Except that it the whole system crashed when when viewing a 1080p Youtube video.
http://teletube.studio4plus.com/
I was wondering if anyone has managed to set-up SpotiMC on XBMC for RPI.
http://forum.xbmc.org/showthread.php?tid=125147
Or this other methood to get spotify in XBMC.
http://openelec.tv/forum/13-miscellaneous/7010-spotify#15766
Has anyone managed to get opera working with flash?
http://openelec.tv/forum/13-miscellaneo ... tify#15766
Sincerly,
Ric
Linux Newb
