512MB RAM on Slackware ARM?
by Penthux » Sun Nov 04, 2012 11:26 am
Hi folks,
Sorry if this is a noob question and/or it's been asked before.
Has anybody managed to get their Raspberry Pi model B working with Slackware ARM using the full 512MB RAM? If so, how did you achieve it? :)
Many thanks,
Penthux
http://rpi.fatdog.eu
"The best school in the world is life and the greatest teacher is yourself."
by sorinm » Sun Nov 04, 2012 7:32 pm
Update to the latest firmware https://github.com/raspberrypi/firmware
Also splitting ram to the gpu is now done in /boot/config.txt and not start.elf anymore.
by Penthux » Sun Nov 04, 2012 8:56 pm
sorinm wrote:Update to the latest firmware https://github.com/raspberrypi/firmware
Thanks, will do that right away! :)
Penthux
by Penthux » Sun Nov 04, 2012 11:16 pm
After trying several methods of updating the firmware and failing miserably at every attempt, I went back to an idea a friend had about simply updating to kernel 3.6.1 (and modules) using installpkg. That works!!! but only after installing the arm496_start.elf file, overwriting the default start.elf. Now I can see i have almost 500MB RAM.
It seems the config.txt is not controlling my RAM allocation at all, much the reverse. Right now I have specified gpu_mem=32 in config.txt but the system is still only giving me 16MB because I have arm496_start.elf in my boot directory.
Thanks for trying to help, but it turns out the solution was the exact opposite of the advice you gave me. :)
Penthux
by sorinm » Mon Nov 05, 2012 1:30 pm
You didn`t update all the firmware files. Somewhere .. you messed up something. arm496_start.elf doesn`t control the amount of ram going to the gpu. Only start.elf controlled that but now this is done in config.txt
Before config.txt, you allocated ram to gpu only renaming arm496_start.elf to start.elf .
by Penthux » Mon Nov 05, 2012 6:01 pm
sorinm wrote:You didn`t update all the firmware files. Somewhere .. you messed up something. arm496_start.elf doesn`t control the amount of ram going to the gpu. Only start.elf controlled that but now this is done in config.txt
I have a Raspberry Pi working perfectly and running Slackware ARM 13.37 - WITH 480MB SYSTEM RAM / 32MB GPU RAM!
Penthux
by Penthux » Fri Nov 09, 2012 12:52 am
... and I have to apologise and eat humble pie (instead of Raspberry Pi) because the fault was with the SDHC card I was using - i.e. unbranded, cheap & chearful. I recently switched to Kingston SD10G2 cards and hey presto, everything you advised me to do worked first time, every time! Thanks. :)
Penthux
by sorinm » Fri Nov 09, 2012 8:31 am
No problem, I advise you to use SanDisk, you can`t go wrong with it ! ;)
by Penthux » Fri Nov 09, 2012 5:34 pm
Ooops... SanDisk is the SDHC card that gave me problems in the first instance. Sorry I will be avoiding them like the plague.
Penthux
by itimpi » Fri Nov 09, 2012 7:49 pm
Penthux wrote:Ooops... SanDisk is the SDHC card that gave me problems in the first instance. Sorry I will be avoiding them like the plague.
I have had no trouble with Sandisk cards. You do, however, have to be careful when buying them via eBay as reputedly about 70% of the ones there are fake.
by HiroProX » Tue Dec 11, 2012 4:26 am
Okay, I've switched out the firmware etc. Do I need to change my kernel to get all of the ram to show up?
