Slackware ARM 14.0
by kerml » Thu Nov 01, 2012 2:40 pm
Anyone working on this?
Amor de Slackware
Portugal 2007
by Cloudcentric » Thu Nov 01, 2012 7:15 pm
kerml wrote:Anyone working on this?
If you follow this page to compile you own, just use the current repositories will achieve ArmedSlack 14
http://www.daves-collective.co.uk/raspi/
I know everything about nothing"
by sorinm » Fri Nov 02, 2012 12:16 pm
I`m hoping for a Hard Float Slackwarearm 14.0. I don`t see any advantages in running a SF distribution on the Pi.
Eric Hameleers , a Slackware developer, said he`s working on a HF Slackware ARM port but that was 10 months ago ..
http://alien.slackbook.org/blog/happy-new-year-2012/
by kerml » Sun Nov 04, 2012 9:04 pm
Hello!
I followed the instructions on http://www.daves-collective.co.uk/raspi ... ling.shtml
But I used a new Slackware ARM Installer Image
Available in here
http://ponce.cc/slackware/slackwarearm- ... pi-extras/
Enjoy
http://ponce.cc/slackware/slackwarearm-14.0/
Thanks to the folks that made this available!
Amor de Slackware
Portugal 2007
by Penthux » Mon Nov 12, 2012 8:33 pm
You might find some usefulness out of this Slackware ARM on a Raspberry Pi site...
http://rpi.fatdog.eu
Penthux
http://rpi.fatdog.eu - Slackware ARM on a Raspberry Pi
http://rpi2.fatdog.eu - Slackware ARM on a Raspberry Pi 2
"The best school in the world is life and the greatest teacher is yourself."
by ponce » Tue Nov 13, 2012 11:03 am
if you're looking for some up2date stuff try these
http://ponce.cc/slackware/slackwarearm- ... as-3.2.27/
this installer image should work fine (I found some time to test it)
sorinm wrote:Eric Hameleers , a Slackware developer, said he`s working on a HF Slackware ARM port but that was 10 months ago ..
he said that his port won't be compatible with the raspi as it's targeted to upper class CPUs :(
by kerml » Sun Nov 18, 2012 12:36 pm
The raspi-slack-installer_11Nov12.img.gz from http://ponce.cc/slackware/slackwarearm- ... as-3.2.27/ didn't work on my rpi 256 MB
I had to use the installer from 30Nov12
After that I mounted /dev/mmcblk0p1 on /boot and run the rpi-update
Amor de Slackware
Portugal 2007
by kerml » Wed Nov 21, 2012 9:22 am
kerml wrote:The raspi-slack-installer_11Nov12.img.gz from http://ponce.cc/slackware/slackwarearm- ... as-3.2.27/ didn't work on my rpi 256 MB
*30Out12
Amor de Slackware
Portugal 2007
by ponce » Wed Nov 21, 2012 3:59 pm
on slackware you have to install slackware packages, it's discouraged to use in parallel rpi-update: installing thingies with that, you will easily lose track of what is installed and where on the system, that's what package managers are for and the reason why dave provided slackbuilds scripts to create these packages in the first place.
in the meantime I updated the stuff here (3.6.6 kernel, firmware-next and userland-next)
and installed another unit (256Mb here too) from scratch with this installer image, raspi-slack-installer_20Nov12.img.gz
by kerml » Thu Nov 22, 2012 3:42 pm
I know that the rpi-update is not the slackware way of doing things but I followed this http://rpi.fatdog.eu/?p=rpiupgrade
But I will try to do the upgrade using the packages!
Amor de Slackware
Portugal 2007
by kerml » Fri Nov 23, 2012 10:45 am
It worked!
:D
Amor de Slackware
Portugal 2007
by kerml » Sun Dec 02, 2012 5:42 pm
I get this message after configuring NFS and start the rc.nfsd
/etc/rc.d/rc.nfsd start
FATAL: Module nfsd not found
Is this a kernel problem?
Amor de Slackware
Portugal 2007
by ponce » Mon Dec 03, 2012 3:39 pm
yes, because I forgot to enable the nfs server module while preparing the config: I'll rebuild one with that enabled, should be ready tomorrow :)
by ponce » Tue Dec 04, 2012 9:33 am
the new kernel with the nfs module is available in the same place
by kerml » Mon Dec 10, 2012 3:10 am
:D
Amor de Slackware
Portugal 2007
by kerml » Tue Feb 05, 2013 9:19 am
Why Slackware ARM don't have a section like FreeBSD?
I keep using updates from http://ponce.cc/slackware/slackwarearm-14.0
It's always new things in there!
The Slackware community don't deserve their own section?
Amor de Slackware
Portugal 2007
by Cloudcentric » Tue Feb 05, 2013 9:39 am
kerml wrote:Why Slackware ARM don't have a section like FreeBSD?
Quite agree the Slackware Forum is required http://armedslackpi.blogspot.co.uk
by kerml » Tue Feb 05, 2013 10:34 am
My ideia is put in here all the links and info that is out there about Slackware ARM.
BTW: I'm starting a project. I will build a wireless router with a rpi 512 mb model B version 2.0 + 4 ports 100 mbits switch + wifi USB dongle.
My purpose is to learn about networking, iptables and etc...
Amor de Slackware
Portugal 2007
by kerml » Mon Apr 22, 2013 9:02 am
Ponce did you stopped releasing updates on your site?
Amor de Slackware
Portugal 2007
