Arch Linux "startx" command not found.
by weirdfish00 » Mon Aug 06, 2012 9:49 am
My raspberry pi keeps saying when i type "startx" that the command is not found can any1 help? :?:
weirdfish
by alexchamberlain » Mon Aug 06, 2012 10:10 am
Have you installed anything? Arch doesn't come with X by default.
Developer of piimg, a utility for working with RPi images.
by weirdfish00 » Mon Aug 06, 2012 12:34 pm
alexchamberlain wrote:Have you installed anything? Arch doesn't come with X by default.
Yes i have installed everything this tutoriol has said i needed to install
weirdfish
by weirdfish00 » Mon Aug 06, 2012 12:37 pm
i might just get a new operating system either ubuntu or debian. I switched from debian because i forgot to set up a root password so i cant install anything! :evil:
weirdfish
by bredman » Mon Aug 06, 2012 12:44 pm
You don't need a root account on Debian. Just put sudo in front of a command to gain root permission, for example
sudo apt-get install example_software
by alexchamberlain » Mon Aug 06, 2012 12:46 pm
Don't give up - Arch is much better. What tutorial were you following?
by Joe Schmoe » Mon Aug 06, 2012 1:22 pm
bredman wrote:You don't need a root account on Debian. Just put sudo in front of a command to gain root permission, for example
Exactly. Just get in the habit of typing "sudo" in front of every single command and you will never have to worry about this root stuff ever again. Think of "sudo" as the modern equivalent of brainf****'s "PLEASE" command. Politeness is always a virtue, and never out of place.
Oh, how I wish that the signature facility on this board weren't so broken.
It is broken in that every time you change your signature, all of your posts reflect the change, not just those going forward.
by jojopi » Mon Aug 06, 2012 2:25 pm
Joe Schmoe wrote:Think of "sudo" as the modern equivalent of brainf****'s "PLEASE" command.
I think you mean INTERCAL. http://www.muppetlabs.com/~breadbox/intercal-man/
by Joe Schmoe » Mon Aug 06, 2012 2:43 pm
Yes, you're probably right. BF's operators are all single character (I think).
by weirdfish00 » Tue Aug 07, 2012 8:07 am
oh no i seem to have started an huge online argument
weirdfish
weirdfish
by maribu » Thu Aug 09, 2012 8:48 am
You need to instal xorg-xinit. Try
pacman -Sy xorg-xinit
Good luck
btw: You need a file called .xinitrc which is a shell script which points the application which you want to start, like openbox-session or lxde
by weirdfish00 » Thu Aug 16, 2012 4:44 pm
maribu wrote:You need to instal xorg-xinit. Try
Good luck
DONE IT. DIDNT WORK. MOVED ONTO DEBIAN. GOT THAT WORKING.
:D :D :D :D :D :D
weirdfish
by sotris99 » Sun Aug 26, 2012 2:33 pm
i always get the no screens found error...
http://www.youtube.com/watch?v=QnuJeVSoFY4
Ἓν οἶδα, ὅτι οὐδὲν οἶδα. (All I know is that I know nothing)
by rahulrasal30 » Tue Jul 08, 2014 12:50 pm
Hello Guys,
Same problem here...!
my Board is rsp_B:
i used on ArchLinux image.
my final aim is to run my a GUI exe programm.
But i ocuur ,
-bash: startx: command not found.
I unserstand X toolkit not here.
but X11 Directory is run up. follow are found .
/etc/X11/xinit/xinitrc.d/30-dhus
can i install X-server OR some ideas about above (/etc/X11/xinit/xinitrc.d/30-dhus) this file?
Answer mi?
by pepedog » Wed Jul 09, 2014 11:24 am
pacman -Sy xorg-xinit xf86-video-fbdev
Then
/usr/bin/xinit /fullpathto/guiexe
or mess with xinitrc https://wiki.archlinux.org/index.php/Xinitrc
by Ivan Tham » Thu Sep 04, 2014 8:14 am
To use lxde in Arch:
pacman -Sy xorg-xinit xorg-server xf86-video-fbturbo-git lxde
Add exec startlxde to .xinitrc. Then
startx
