WARN:hc_xfer_timeout
by Unlucky » Thu May 31, 2012 9:22 am
Hi guys,
I'm getting an issue with the Fedora Remix 14 in which i get
DEBUG:timer_callback:: Timer hc timer callback
WARN::hc_xfer_timeout:1740 ...
WARN::hc_xfer_timeout:1742 ...
Now while I'm perfectly happy to go off and venture around to try and research and fix it, it's incredibly annoying that those messages keep appearing every few seconds while I'm trying out fixes. Is there any way to suppress them for a session so I can get on with fixing?
Thanks in advance! :)
G
by mikebiggs » Mon Jun 04, 2012 6:44 am
You're not alone on this one. I've tried several SD cards and get this issue on all of them. SD cards seem to be the weak link with the RPi, very frustrating. Much rather being troubleshooting and debugging my own code on a project instead of just getting the thing to load. ...back to Debian for now :)
by jsgriffin » Thu Jun 07, 2012 6:48 pm
I'm having this problem too using a SanDisk 16GB SDHC Class 4 card. Has anyone got a solution to this yet?
by dominik » Tue Jun 12, 2012 8:36 pm
which version of the linux kernel you are using?
uname -a
by dominik » Sat Jun 16, 2012 6:17 pm
In fedora 17 upgrading kernel to 3.1.9+ solved this issue for me.
by HTWingNut » Sun Jul 01, 2012 10:25 pm
I've tried 3 cards: Kingston 4GB Class 4, PNY 8GB Class 6, Transcend 16GB Class 10 all with the same result. I can't even get it started. I know very little about linux and was hoping to delve into it a bit with Raspberry Pi. Heck with Debian I didn't even know to type: StartX to start the GUI. It was not documented anywhere. But that's how much of a newb I am at this.
by dominik » Mon Jul 02, 2012 8:21 pm
try to log in in text mode, type the command
uname -a
and post the output.
by odelcarmen » Sun Jul 08, 2012 3:23 am
Same here. I just loaded a Fedora Remix image to my Kingston 4GB SDHC and similar error messages keep on prompting.
I will just focus with my Debian Squeeze for now (seems to be more stable for me).
Keep posting for developments.
Cheers!
by jamesh » Sun Jul 08, 2012 5:21 am
I'd recommend going with Debian Wheezy, its faster than Squeeze and just as reliable.
Volunteer at the Raspberry Pi Foundation, helper at Picademy September, October, November 2014.
by odelcarmen » Thu Jul 12, 2012 2:46 pm
jamesh wrote:I'd recommend going with Debian Wheezy, its faster than Squeeze and just as reliable.
Ok. Just downloaded the image for Debian Wheezy. I'll try my RPi to boot from it this weekend.
Thanks.
by robertjw » Mon Jul 23, 2012 10:47 pm
Still seeing this problem on the latest f17 cli nightly (f17arm-20120717-004502-arm-rpi-mmcblk0). It uses this kernel:
Linux fedora-arm 3.1.9 #1 PREEMPT Sat Mar 3 21:58:00 UTC 2012 armv6l armv6l armv6l GNU/Linux
by itimpi » Tue Jul 24, 2012 5:29 am
That is now a very old kernel without any of the improvements that have been made to SD card handling.
