No updates with YUM
by shelmed » Fri Jun 21, 2013 8:15 am
Hi, I have been using Pidora on and off now for the past few mths.
Each time I run: # yum update in a terminal it states there are no new updates.
Just doesn't seem right to me.
Am grateful for any help/advice :)
by timl » Sun Jun 23, 2013 6:45 am
that's funny. I have only received about 2 updates in the 3 weeks I have used pidora. I am assuming that the team are beavering away on pid 19 but it would also be interesting to receive any comments!
by bce_2013 » Sun Jun 23, 2013 12:53 pm
I'm using pidora, with an ssh connection and trying to update my system with "sudo yum update".
It appears that the repository url is incorrect. what is the correct url for yum? Below is the error message that I am receiving. Thanks
[erwinb@raspi ~]$ sudo yum update
[sudo] password for erwinb:
Loaded plugins: langpacks, presto, refresh-packagekit
http://pidora.proximity.on.ca/pidora/up ... repomd.xml: [Errno 14] HTTP Error 403 - Forbidden : http://pidora.proximity.on.ca/pidora/up ... repomd.xml
Trying other mirror.
http://downloads.raspberrypi.org/pidora ... repomd.xml: [Errno 14] HTTP Error 404 - Not Found : http://downloads.raspberrypi.org/pidora ... repomd.xml
Error: failure: repodata/repomd.xml from pidora-updates: [Errno 256] No more mirrors to try.
by Joe Schmoe » Sun Jun 23, 2013 2:04 pm
I was getting that garbage until I did:
yum clean all
Then the next time you run any yum command, it will download new, clean, "control files", and then things will work again.
Faced with the choice between changing one's mind and proving that there is
no need to do so, almost everyone gets busy on the proof.
- John Kenneth Galbraith -
by tedsluis » Sun Jun 23, 2013 2:37 pm
yum clean all
I am experiencing an issue to. Before it worked well, until now:
[root@raspi ~]# yum update
Could not retrieve mirrorlist http://pidora.ca/mirrorlist/mirrorlist.cgi?repo=pidora-18&arch=armhfp error was
14: curl#6 - "Couldn't resolve host"
Error: Cannot find a valid baseurl for repo: pidora/18/armhfp
[root@raspi ~]#
It is not possible to ping http://www.pidora.ca.
[root@raspi ~]# ping www.pidora.ca
ping: unknown host www.pidora.ca
[root@raspi ~]
My DNS works fine, but I was not able to resolve the IP address of the site. I suspect that he pidora.ca site is no longer available as a DNS entry.
--- If you cannot divide then you cannot multiply. ---
by bce_2013 » Sun Jun 23, 2013 4:06 pm
I ran the "sudo yum clean all" and with the messages below. Are the servers being turned off for the weekend?
Cleaning repos: pidora pidora-rpfr-updates pidora-updates
Cleaning up Everything
No delta-package files removed by presto
Could not retrieve mirrorlist http://pidora.ca/mirrorlist/mirrorlist. ... rch=armhfp error was
[erwinb@raspi ~]$ ping pidora.ca
ping: unknown host pidora.ca
[erwinb@raspi ~]$
by yoyojacky » Sun Jun 23, 2013 4:37 pm
I used to use this command:
# yum clean all && yum -y update if you can not ping some web site by domain name ,you'd better check /etc/resolv.conf 's content,
inside maybe like this :
nameserver 8.8.8.8
nameserver 9.9.9.9
nameserver 6.6.6.6
and also you can use this command to check if you can reslove that domain name.
# nslookup www.raspberrypi.org
or enter into interactive mode just use nslookup .....
haha , i hope it can help you. :lol:
easy life easy linux....
no brother no linux....
Let's make the world better...
By yoyojacky
by canadatools » Sun Jun 23, 2013 5:59 pm
I am having the same issue as tedsluis, pidora.ca cannot be reached. I did a reverse look up on the domain and got the ip to try that route but still no go. Maybe pidora is moving their server?
by tedsluis » Sun Jun 23, 2013 7:09 pm
yoyojacky wrote:I used to use this command:
nameserver 8.8.8.8
nameserver 9.9.9.9
nameserver 6.6.6.6
# nslookup http://www.raspberrypi.org
I believe my "/etc/resolve.conf" is okay:
[root@raspi ~]# cat /etc/resolv.conf
# Generated by NetworkManager
domain bachstraat20
search bachstraat20
nameserver 192.168.11.1
nameserver 8.8.8.8
nameserver 8.8.4.4
[root@raspi ~]#
Resolving works:
[root@raspi ~]# ping raspberry.org
PING raspberry.org (208.87.35.103) 56(84) bytes of data.
64 bytes from 208-87-35-103.securehost.com (208.87.35.103): icmp_seq=1 ttl=44 time=126 ms
64 bytes from 208-87-35-103.securehost.com (208.87.35.103): icmp_seq=2 ttl=44 time=126 ms
64 bytes from 208-87-35-103.securehost.com (208.87.35.103): icmp_seq=3 ttl=44 time=124 ms
^C
--- raspberry.org ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 124.547/125.872/126.727/1.034 ms
[root@raspi ~]#
nslookup too:
[root@raspi ~]# nslookup raspberry.org
Server:      192.168.11.1
Address:   192.168.11.1#53
Non-authoritative answer:
Address: 208.87.35.103
[root@raspi ~]#
But it does not work when I try the Pidora.ca domain:
[root@raspi ~]# nslookup pidora.ca
;; connection timed out; trying next origin
** server can't find pidora.ca: NXDOMAIN
[root@raspi ~]#
I suspect an issue with the pidora.ca domain.
If you want to visit the site Pidora.ca site with the installation instructions, the wiki and the download links, you can use this link: http://pidora.proximity.on.ca/
by tedsluis » Mon Jun 24, 2013 4:14 pm
http://www.pidora.ca is back! I got an email from Chris Tyler at Seneca. They had a DNS server crash (heat issue):
Address: 198.57.186.36
[root@raspi ~]#
But yum still doesn't work:
pidora        | 3.9 kB  00:00:00
pidora-rpfr-updates        | 3.8 kB  00:00:00
http://pidora.proximity.on.ca/pidora/updates/18/armhfp/repodata/repomd.xml: [Errno 14] HTTP Error 403 - Forbidden : http://pidora.proximity.on.ca/pidora/updates/18/armhfp/repodata/repomd.xml
http://downloads.raspberrypi.org/pidora/updates/18/armhfp/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found : http://downloads.raspberrypi.org/pidora/updates/18/armhfp/repodata/repomd.xml
[root@raspi ~]#
It seems I don't have permission to access to http://pidora.proximity.on.ca/pidora/updates/18/armhfp/repodata/repomd.xml or that repodata does not exists on the server.
It is the same with the mirror http://downloads.raspberrypi.org/pidora/updates/18/armhfp/repodata/repomd.xml.
Below http://pidora.proximity.on.ca/pidora/updates/18/ all is gone.
I found a bug tracker report for this yum update issue: http://trac.proximity.on.ca/projects/rpfr/ticket/346. And oatley reports in it that he is working on a fix!
