music
by ChadP » Sat Aug 11, 2012 4:28 pm
What would be a good music player and how can i download and install it? Thanks!
by redhawk » Sat Aug 11, 2012 7:42 pm
I use qmmp under X-Windows it's the closest thing to Winamp for Linux (and xmms / x11amp) it also supports Winamp skins.
To install: sudo apt-get install qmmp once it's up and running you need to turn off the graphic equaliser.
Richard S.
by gregjo » Mon Aug 13, 2012 4:33 pm
redhawk wrote:To install: sudo apt-get install qmmp once it's up and running you need to turn off the graphic equaliser.
Since this is a Fedora sub-forum, that command would be, as root:
# yum install qmmp
by ChadP » Sat Aug 18, 2012 5:18 pm
Can i just put music on my usb drive? Copy music from my mac to the thumb drive plug it into the rpie then what? Thanks for all your guys help!
by ChadP » Sat Aug 18, 2012 5:47 pm
I have it installed but when i play a song it cuts out real bad then kinda freezes
by redhawk » Sat Aug 18, 2012 6:17 pm
Did you turn off the graphic equaliser??
Richard S.
by ripperus » Fri Sep 28, 2012 7:34 pm
Hi
To better performance turn off EQ
