Compiling Quake III fails on Debian 012-06-18-wheezy-beta
by charlelie » Tue Jun 26, 2012 9:25 pm
Hi
I'm trying to compile Q3 but I have an error.
I'm following this tuto : viewtopic.php?t=6511&p=83593
Anyway it stops with a fatal error -
GLES/gl.h: no such file or directory compilation terminated
, on files depending on renderer/qgl.h
In the specified line in qgl.h, where is
#ifdef VCMODS_OPENGLES
#include <GLES/gl.h>
The gl.h exists in /opt/vc/include/GLES
Do you have any idea ?
Thank you
by jerry.tk » Wed Jun 27, 2012 7:14 am
There were some changes in the build script recently. Try following this recipe: Compiling Quake3 on Raspbian. Do not worry about Raspbian being mentioned there, it applies to plain Debian too.
by charlelie » Fri Jun 29, 2012 8:45 pm
You are right ! Thank you very much. Q3 works now ! (but unlike others, I don't have 60 fps and its a quite unplayable on bigs maps with < 20 fps, like on the 3th map)
Tip : to show FPS, push tild and type
/cg_drawfps 1
Before, a was having opengl init error. Because binaries found here were not for wheezy or the current firmware, I guess.
eglCreateWindowSurface() failed
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLimp_Init() - could not load OpenGL subsystem
