screen settings
by moghm » Mon Jun 25, 2012 12:20 pm
Hi guys,
I have a few questions.
(1) i flashed the debian image on an SD card and was able to boot debian succesfully on my plasma. My plasma is a 1080p model and I believe the max resolution to be 1920 x 1080. Once I type startx I am taken to the gui squeeze screen. The screen fit on the plasma is perfect, but soon after some adjustmnets take place and the size of the screen is altered i.e. I lose the top and bottom borders. Tried to adjust this in debian screen settings but only 2 resolutions are available including auto and another one. Any ideas ?
(2) Also, can I use a HDMI to DVI adaptor to a monitor. Heard some mixed reports on this ?
many thanks
by RaTTuS » Mon Jun 25, 2012 2:44 pm
HDMI to DVI adapters work fine - I have one in use
http://elinux.org/RPi_config.txt#Video_mode_options <- disable overscan ?
http://www.catb.org/esr/faqs/smart-questions.html Ask Questions
http://www.raspberrypi.org/forums/viewtopic.php?f=29&t=7192 AutoStart Script
"That's not right, the badgers have moved the goalposts."
by moghm » Mon Jun 25, 2012 10:42 pm
Many thanks for that. I am learning hence the numerous questions. So basically I need to set disable_overscan=0 ?
Also, I noticed some HDMI settings.if I set hdmi_drive= 2 that means that sound will be sent via the hdmi cable ?
thanks once again
