login
by doronfynn » Wed May 30, 2012 11:39 am
just got my pi booted with debian at login i put in pi at password it will not let me type any thing in can you help i am new to all this
by stevepdp » Wed May 30, 2012 11:46 am
I might be misunderstanding your question. If you're looking for the correct login details for the latest Debian image, they are as follows:
username: pi
password: raspberry
If you literally cannot type anything, do you perhaps have another keyboard handy?
I'm not a part of the Raspberry Pi Foundation, I'm just an enthusiastic fan.
by felix123 » Wed May 30, 2012 11:51 am
You're not supposed to be able to type anything at the password prompt. It's designed like this.
by doronfynn » Wed May 30, 2012 12:47 pm
felix123 wrote:You're not supposed to be able to type anything at the password prompt. It's designed like this.
not sure i understand, do you mean you don,t type in the password
by stevepdp » Wed May 30, 2012 12:58 pm
Here's how the login process should work.
1. You're presented with the login prompt.
2. You enter "pi" as the user.
3. You hit return/enter.
4. You're then asked for a password.
5. You type "raspberry" baring in mind that the password entry is invisible.
6. You hit return/enter again to confirm.
7. You're then logged in.
I now understand the difficulty you've experienced doronfynn. The password entry is invisible because it's a security feature. It's similar to how password entries are often marked ******* on websites or most programs.
Let us know how you get on.
(Thanks felix123 :-))
by milopware » Wed May 30, 2012 6:48 pm
I am having the same problem, i have debian6-17-02-2012 which seems to boot fine from the memory card but i try logging in with username pi password raspberry but just get incorrect username or password. is there a different username / password for this version? i cant find it anywhere if there is. i know there is a newer version but it doesnt even boot when i use that image (debian6-19-04-2012), i get lots of errors then it says spawning too fast waiting for 5 minutes and thats about it.
Please help!!!
by doronfynn » Wed May 30, 2012 9:22 pm
stevepdp wrote:Here's how the login process should work.
t
Thanks for your help it worked ok must be dim not have worked that out
by JeremyF » Wed May 30, 2012 11:02 pm
milopware wrote:I am having the same problem, i have debian6-17-02-2012 which seems to boot fine from the memory card but i try logging in with username pi password raspberry but just get incorrect username or password. is there a different username / password for this version? i cant find it anywhere if there is. i know there is a newer version but it doesnt even boot when i use that image (debian6-19-04-2012), i get lots of errors then it says spawning too fast waiting for 5 minutes and thats about it.
Please help!!!
Debian February 17th has username/password pi/suse.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
by devnull » Thu May 31, 2012 8:19 am
debian6-19-04-2012 - password is also suse !!
> /dev/null 2>&1
by xtramural » Thu May 31, 2012 8:44 am
devnull wrote:debian6-19-04-2012 - password is also suse !!
The password for that release is raspberry
by devnull » Thu May 31, 2012 10:23 am
I can assure you it most definitely is NOT raspberry, as I have just downloaded and installed it, raspberry is not accepted as password either via ssh or local terminal.
The password is suse on the version I downloaded "debian6-19-04-2012"
Cheers
> /dev/null 2>&1
by gornyjw01 » Fri Jun 01, 2012 1:29 pm
Hiya folks,
I'm also having the same problem trying to log into debian6-19-04-2012
I've tried using the username/pw combos, pi/raspberry and pi/suse but neither seem to be working. Any ideas? I'm completely new to programming.
by gornyjw01 » Fri Jun 01, 2012 3:45 pm
Just done a new image onto my card and everything seems to be working with username- pi password- raspberry
by grumpyoldgit » Fri Jun 01, 2012 4:17 pm
The Debian6 19-04-2012 password is definitely raspberry.
by extremx » Wed Jun 06, 2012 5:21 am
pi / raspberry didn't work for me either. I did however get root / root to work and let me in.
Once i was in i checked the /etc/shadow file and there was no shred of evidence that there was any other users. Not sure what is going on, but the info doesn't seem to be consistent.
root@raspbmc:~# cat /etc/shadow
root:$6$uqz4Qpb3$3uLIyHzVwA9QCVfAZFo1K4AyWFutYyi/W9wRySAdnTPuomgNfsasgK1ralpJ.f4JektvHuiELa0vOJnhscyhG.:15492:0:99999:7:::
daemon:*:15492:0:99999:7:::
bin:*:15492:0:99999:7:::
sys:*:15492:0:99999:7:::
sync:*:15492:0:99999:7:::
games:*:15492:0:99999:7:::
man:*:15492:0:99999:7:::
lp:*:15492:0:99999:7:::
mail:*:15492:0:99999:7:::
news:*:15492:0:99999:7:::
uucp:*:15492:0:99999:7:::
proxy:*:15492:0:99999:7:::
www-data:*:15492:0:99999:7:::
backup:*:15492:0:99999:7:::
list:*:15492:0:99999:7:::
irc:*:15492:0:99999:7:::
gnats:*:15492:0:99999:7:::
nobody:*:15492:0:99999:7:::
libuuid:!:15492:0:99999:7:::
ntp:*:15492:0:99999:7:::
sshd:*:15492:0:99999:7:::
Also:
root@raspbmc:~# ls /home/
root@raspbmc:~#
/me shrugs
