How to install pyserial?
by prodata » Tue May 15, 2012 5:10 pm
Sorry, me again... but almost there now!
I need to install pyserial (which doesn't seem to be there in the Debian Python by default) in order to talk to a serial device. Naively, I tried:
sudo apt-get install pyserial
but that fails (as pyserial can't be found). Is there a simple way of getting it and also placing it in its correct Python directory, perhaps all with a single command? Or is that expecting too much?
by croston » Tue May 15, 2012 5:20 pm
From memory:
$ sudo apt-get install python-serial
or
$ sudo apt-get install python3-serial
If I am wrong, you can search Debian packages using:
$ aptitude search serial
by prodata » Tue May 15, 2012 5:24 pm
Thanks - magic. Wasn't sure about the installation line that said ' ...processing triggers for python-central...' though.
by fabads » Thu Jan 16, 2014 1:50 pm
Using this method, pyserial was installed but I was unable to launch the provided tools with the pyserial distribution (list_port, miniterm etc).
First I installed pip then installed pyserial module from pip:
sudo apt-get install python-pip
sudo pip install pyserial (add --upgrade if you installed previousliy using the first method)
Hope it helps.
Fabrice
by Loonhaunt » Sun Mar 02, 2014 3:25 pm
fabads wrote:Hi,
Hope it helps.
Fabrice
Did you ever get this to work???
Dave
