WeDo + Scratch working!
by Myra » Tue Jul 10, 2012 10:27 pm
I now have the WeDo crocodile happily chomping on my finger, powered by my Pi, thanks to some help from Alex Bradbury. In order to make this happen you need to add a udev rule which makes the WeDo USB hub readable and writable by the pi user.
Go to directory
/lib/udev/rules.d
make a file called "40-scratch.rules" that contains the following:
ATTRS{idVendor}=="0694", ATTRS{idProduct}=="0003", SUBSYSTEMS=="usb", ACTION=="add", MODE="0666", GROUP="plugdev"
Then start up Scratch, plug in your WeDo USB hub, and the motor control blocks should show up in the Motion area.
Hooray, chomping crocodiles for everyone!
by Myra » Wed Jul 11, 2012 8:43 am
Hmmm, I think my announcement was a bit premature. This udev rule works with the Scratch on the new wheezy distribution, but not on squeeze. At least it doesn't work on the version of squeeze that I've got!
by asb » Wed Jul 11, 2012 9:15 am
We're moving to wheezy anyway. Very possibly the version of squeak-plugins-scratch used in the wheezy distribution didn't have WeDo, or maybe the pi user isn't a member of the plugdev group (if that's the problem, running scratch as root should still allow WeDo to work).
by FangW » Wed Mar 25, 2015 5:40 am
Hi, I just purchased rasberry pi 2 ultimate kit and trying to connect WeDo USB hub to it.
Following the instructions above to create the rule file, but the usb connection is not working. Motor can't be turned on and sensor value is not changing.
Here is dmesg output which looks fine to me:
[ 86.668920] usb 1-1.2: new low-speed USB device number 12 using dwc_otg
[ 86.818378] usb 1-1.2: New USB device found, idVendor=0694, idProduct=0003
[ 86.830740] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 86.843443] usb 1-1.2: Product: LEGO USB Hub V1.00
[ 86.869818] hid-generic 0003:0694:0003.0005: hiddev0,hidraw0: USB HID v1.10 Device [LEGO USB Hub V1.00] on usb-bcm2708_usb-1.2/input0
more /lib/udev/rules.d/40-scratch.rules
Thanks.
Fang
