APL
Drop in for a chat and a cup of tea
by RMW5 » Thu Mar 08, 2012 2:22 pm
Would anybody be interested in a port of APL?
Leaving aside the issue of "funny" character set it has the advantage of being highly interactive, procedure driven and extremely powerful handling multi-dimensional arrays, surprisingly useful when applied to school maths problems.  It also requires only a console type interface.
I first used APL 35 years ago on an IBM 5100 (came out 7 years before the IBM PC), and if IBM could get an APL interpreter to work on a  machine with an average instruction time of 1.75 microseconds and 64k of memory, then it should run very well in an R-PI.
by jamesh » Thu Mar 08, 2012 4:27 pm
Try here, might be somethign already available.
http://www.thefreecountry.com/...../apl.shtml
Volunteer at the Raspberry Pi Foundation, helper at Picademy September, October, November 2014.
by RMW5 » Thu Mar 08, 2012 5:03 pm
I think there is something already available if you run a derivative of APL over WINE, but I was thinking of taking the NARS 2000 source code which is a superset of classic APL and cutting it down to the original and porting it to Linux.
by andyl » Thu Mar 08, 2012 5:16 pm
J and OpenAPL should just need compiling on the target machine.
But generally I would guess there will be plenty of people who would welcome a new port of an APL implementation, independently of whether it is for the PI or not.
by RMW5 » Thu Mar 08, 2012 7:44 pm
J is probably not a good place to start for beginners and OpenAPL has a few bugs / kludges that you can spot in the source code.  Also I thought some custom system variables to interface to the PIO and other devices might be neat: []PIO <- 1 0 1 0 1 0 0 0 etc.
by Bakul Shah » Thu Mar 08, 2012 9:25 pm
I did see one post about the "Pi on comp.lang.apl! And I thought I read about APL on iPad but can"t find anything on it right now.
If nothing else I will get `kona" (opensource `k") running on the "Pi for sure since I often use it for scripts or as a desk calculator.
Here is an excellent tutorial on K: http://www.cs.nyu.edu/courses/.....intro.html — It was written for K from kx.com (and this commercial K is no longer available) but I think the tutorial should work fine with kona.
Check out map/reduce in K:
by SN » Fri Mar 09, 2012 12:06 am
I have in my past working life written code in Cobol, Lisp, Prolog, Fortran and even x86 Assembler but I don't think I'd be wanting to do that again so I won't be looking for interpreters or compilers in any of these for the raspi.
Prolog was a real headscratcher, but very very clever at problem solving ;-)
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
by RMW5 » Fri Mar 09, 2012 11:14 am
"I have in my past working life written code in Cobol, Lisp, Prolog, Fortran and even x86 Assembler..."
Been there done that (plus various versions of Algol, C and variants, more assemblers than I can remember, something called RTL/2 and all the modern webby stuff), and I wouldn't want to go back to those, but APL is different. It is half way between a procedural programming language and MATLAB, highly interactive and in its original form, console based.
When it first came out APL would have been ideal for schools but most schools wouldn't have had the budget for the several million pounds it would have required for an IBM mainframe to host it.
by APLfan » Sat Nov 03, 2012 11:09 am
I think that Dyalog APL has been ported to Raspberry Pi.
Something was reported at their conference "Dyalog '12"
held in Elsinore, Denmark in October, 2012.
by Bakul Shah » Sun Nov 04, 2012 6:28 am
Kona is an open-source implementation of the K programming language. If you don't know APL, then this is the place to start. K is an ASCII-based APL. To build it on the Raspi:
$ git clone  https://github.com/kevinlawler/kona.git
$ cd kona
$ make
To use:
$ rlwrap ./k  # rlwrap for history and command line editing
K Console - Enter \ for help
  3 3 # !9
(0 1 2
 3 4 5
 6 7 8)
  +/3 3 #!9
9 12 15
by maurjor » Fri Jun 14, 2013 11:40 am
Dyalog APL is now available on the RPi. See their website.
If any of the other APL fans on here have projects to excite primary school age (up to 11) children, I'd be delighted to hear from them.
Best Regards,
Maurice Jordan
