Huawei E323 3G Dongle (3 network)
by eeyore.t.mule » Tue Jun 26, 2012 5:19 pm
Evening all, I've just spotted one of these cheap in tesco and it got me wondering has any one tried it will the pi :?:
A quick in shop google indicates that it can work with Linux mint (Ubuntu and thus debien based) so I'm wondering if anyone has tried it.
If not I might have a go :lol: :D
Donkeys like Pi
by gordonendersby » Tue Jun 26, 2012 7:02 pm
Ive got the Huawaei board version in my netbook and its supported under ubunbtu based on debian.
It shows up as a usb device just like the dongle.
I dont think you will have any trouble, lots of howto's on the net to getting it working.
The gotcha is usually the cost of the data plan. I had run mine on a regular sim with a data plan but the provider clamped down on it and barred it from use in dongles or netbooks.
Gordon
by eeyore.t.mule » Tue Jun 26, 2012 8:04 pm
Hopefully I'll be ok :lol:
Mine was ment for an iPhone but works in my iPad too.
I asked about using it in other stuff apart from my iPhone and was told it was ok... I think as long as you don't extract the urine generally you should be ok... I hope :lol:
Donkeys like Pi
Failing that just thinking about it I could use the iPad as a router... ;) :oops: :P
Donkeys like Pi
by edent » Fri Jul 13, 2012 12:26 pm
I've managed to get the E220 working to connect to the net. Try using Sakis http://www.sakis3g.org/
Here's the full details of how I did it
http://shkspr.mobi/blog/index.php/2012/ ... i-success/
by decibyte » Wed Aug 01, 2012 9:31 pm
edent wrote:Try using Sakis
Wow! I thought I should be fiddling around at least a couple of evenings to get a working 3G connection. Now I made it in about an hour. Thanks a lot :)
by jets » Fri May 10, 2013 7:25 pm
Well, I thought it is useful for others to share my experiences with Rpi and Huawei E353.
I struggled for a while with the dongle and latest wheezy. To get it working, what I did was basically just:
-Install usb modeswitch (sudo apt-get install usb-modeswitch)
-Edit /etc/network/interfaces and add this line: "iface eth1 inet dhcp"
-Reboot
Then the eth1 (if you only had eth0 before), will have IP-address, probably 192.168.1.100 or 192.168.1.1 or something similar. Check it with "ifconfig". Then simply add default gateway "sudo /sbin/route add default gw 192.168.1.100 eth1".
To share the Internet connection, do similar script (and execute it):
#!/bin/bash
rm /etc/iptables.sav
sudo iptables -A FORWARD -i eth0 -o eth1 -s 192.168.0.0/24 -m conntrack --ctstat
e NEW -j ACCEPT
sudo iptables -A FORWARD -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
sudo iptables -A POSTROUTING -t nat -j MASQUERADE
/sbin/iptables-save > /etc/iptables.sav
sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
I now have a camera surveillance system with controlled camera electricity outlets (via gpio and standard remote controlled outlets). System has much lower power consumption than the previous system.
All is solar powered :)
by Chandy » Tue Jun 25, 2013 2:59 pm
I am trying to connect huawei e1820 wireless mobile broad band usb modem . But it restarting at the time of connecting.I tried higher current rated (800ma)power supply,but not working somebody please help me
