Raspberry Pi compatible webcam...
28 posts   Page 1 of 2   1, 2
by raspberrypiguy1 » Thu Apr 04, 2013 2:04 pm
I've been wondering, what is the best webcam to use with the Pi? I know that the official camera module is going to be released soon, but I need an earlier fix! I have had a look at RPi verified peripherals, but what it lacks is personal comments... And that why I am asking! Are there any of you who could vouch for a good cheap one that you have already used?
The Raspberry Pi Guy
P.S: Sorry about all these 'ask' posts today! I have a lot of questions!
13... Now 14... Now 15 year old Raspberry Pi tutorial maker, programmer, electronics tinkerer, fascinated by the cosmos & the ISS, loves Physics + Maths. *We are made of star stuff*
by raspberrypiguy1 » Thu Apr 04, 2013 2:12 pm
Also, it will probably need to be powered from the Pi itself... Not from a hub! :D
by gordon77 » Thu Apr 04, 2013 3:44 pm
I'm using a Logitech C270, for stills only though not video , and with the new kernel with the USB improvements I can get 960 x 720 stills :)
They are only approx £17 :)
Gordon77
by raspberrypiguy1 » Thu Apr 04, 2013 6:18 pm
Ah, cool!
But I think I will be needing video, anyone else got any suggestions?!
by raspberrypiguy1 » Thu Apr 04, 2013 7:32 pm
What about one of the PlayStation eye cameras? I thought I saw some people who got those to work? At a good frame rate?
by keble » Thu Apr 04, 2013 8:53 pm
gordon77 wrote:I'm using a Logitech C270, for stills only though not video , and with the new kernel with the USB improvements I can get 960 x 720 stills :)
Gordon77
Hi - I am also using a Logitech C270 - but can't get consistent still performance.
For example, using motion or streamer I can get a couple of images, and then I get error messages.
I've got a pretty recent OS (2013-02-09-wheezy-raspbian) - would this have the "kernel with USB improvements" you mention?
I'm going to run rpi-update now but if you can share how you got success I'd be grateful!
by gordon77 » Thu Apr 04, 2013 9:39 pm
I used rpi-update.
The latest I got is #401, and apart from a SD card issue that a 2gb sd card wasn't big enough it worked fine.
I have only done
Install latest wheezy
Expand to fill card (from menu)
Update raspi-update (from menu)
Rpi-update
I have a rev1 RPi with 256mb ram
I mainly use pygame.camera for still capture.
Gordon77
by keble » Thu Apr 04, 2013 9:44 pm
Many thanks, I'll give that a whirl :)
by gordon77 » Thu Apr 04, 2013 9:51 pm
Try this, it will display all sizes upto 960 x 720 and save them as jpegs
Gordon77
#!/usr/bin/python
import pygame, sys
from pygame.locals import *
import pygame.camera
import time
pygame.init()
pygame.camera.init()
L = []
L = [352,288,640,480,800,600,960,720]
count = 0
while count < 8:
   width = L[count]
   height = L[count+1]
   cam = pygame.camera.Camera("/dev/video0",(width,height))
   cam.start()
   pygame.display.set_caption(str(width) + "x" + str(height) + "  saved as /home/pi/" + str(width) + "x" + str(height) + '.jpg')
   windowSurfaceObj = pygame.display.set_mode((width,height))
   image = cam.get_image()
   catSurfaceObj = image
   windowSurfaceObj.blit(catSurfaceObj,(0,0))
   pygame.display.update()
   cam.stop()
   pygame.image.save(image,str(width) + "x" + str(height) +'.jpg')
   count +=2
   time.sleep(2)
by raspberrypiguy1 » Fri Apr 05, 2013 7:13 am
And you are sure that that camera doesn't do video? I would of thought that if it can handle 960x720 stills that it would at least be able to do low res video?!
by raspberrypiguy1 » Fri Apr 05, 2013 7:23 am
by shuckle » Fri Apr 05, 2013 7:35 am
raspberrypiguy1 wrote:What about one of the PlayStation eye cameras? I thought I saw some people who got those to work? At a good frame rate?
I am using PS3 eye camera with resolution 640x480 and I get reliable 8 fps video.
My model B 256MB raspberry is overclocked to 1000 MHz:
$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
1000000
I use motion (but I have disabled motion detection and only use the video stream to my ZoneMinder system running in bigger computer). CPU load is about 95%:
$ vmstat 1 3000
procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu----
 r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa
 1  0      0  22384  21064 140044    0    0     0     0   20   38 79 16  5  0
 1  0      0  22324  21064 140044    0    0     0     0 3876  137 77 19  4  0
Also the microphone works fine by the way (but that needs to new 3.6.11+ #399 kernel minimum to get adequate sound level)
by raspberrypiguy1 » Fri Apr 05, 2013 10:47 am
Ahhh... OK...
I don't have a PS3, so I don't have a PS3 eye camera... And they (on Amazon) set you back a hefty £20!
What about the PS2 eye camera? Only a couple of quid on Amazon;
http://www.amazon.co.uk/Official-Silver ... ds=eye+ps2
by gordon77 » Fri Apr 05, 2013 10:58 am
raspberrypiguy1 wrote:And you are sure that that camera doesn't do video? I would of thought that if it can handle 960x720 stills that it would at least be able to do low res video?!
I am sure it will, what program do you want to try it with ?
Gordon77
by raspberrypiguy1 » Fri Apr 05, 2013 11:10 am
I don't know what program yet, the goal is for it to display (or stream) video from a robot... I'm not too worried about resolution, as long as its good enough to see surroundings then I'm good!
by raspberrypiguy1 » Fri Apr 05, 2013 5:23 pm
I've taken the £4.75 plunge and bought myself a PS2 Eye toy camera... We will see how that goes!
by gordon77 » Mon Apr 08, 2013 3:20 pm
Gordon77
I tried the C270 with video using guvcviewer and it worked at
320x 240 15fps
352 x 288 15fps
640 x 480 8.5fps
800 x 600 4fps
960 x 720 3.5 fps
all from GUI and using mjpg format
Gordon
by keble » Wed Apr 10, 2013 9:43 pm
gordon77 wrote:Try this, it will display all sizes upto 960 x 720 and save them as jpegs
Gordon77
A belated thanks for this! I got the python script to run (I'm new to this) after weeding out some whitespace that python didn't like - not sure why.
Well, it took 4 snapshots and partly rendered them on the screen (I could see that the resolution was good), then everything has frozen up!
After a reboot I can see that the images have resolutions up to 960x720
I'm beginning to think I either need to reflash (I know that I get USB problems after a forced power-off) or perhaps to get another RPi (in case this one really has got something wrong with it).
However it's clear that the python route can get the resolution I want, so I'll persist with it.
Thanks again
Rob
by keble » Tue Apr 23, 2013 9:38 pm
Here's an update on the above: I've been trying out the pygames camera module and its proving far better than any of the other approaches I tried (eg motion, streamer).
I can now consistently get 640x480 from my Logitech C270 (can also get higher but this is what I want for my time lapse stuff).
Learning python hasn't been too bad, plenty of help out there :)
by parseINT32 » Fri May 03, 2013 7:21 pm
hi, i need a cam to record video through command line...
What about PS2 eyetoy?
Do i need a microphone to record video in background?
by dacmill4 » Sat May 11, 2013 12:44 am
I used a Logitech c210.
Check out the following:
http://www.youtube.com/watch?v=rYKhGfZbj-0
Click on "Show More" in YouTube to get the technical details.
by bobturbos » Fri May 31, 2013 7:14 am
I don’t know which is the best, but I know which is the cheapest. I just bought a £4.99 OPTIMUM 3 megapixel webcam in B&M and worked great for me.
http://www.bmstores.co.uk/products/opti ... cam-251953
bobturbos
by AMazinG » Wed Jun 05, 2013 9:59 pm
i have a Logitech Pro9000, and works perfectly fin giving stable 30fps for 320x240 resolution or below with guvcview. However when I use it with C++ (openCV 2.3) framerate drops to 5-10 fps.
greetz..
[AMG]
by simplesi » Thu Jun 06, 2013 10:43 am
This is what I've been waiting for - someone to find a £5 (retail not car boot ) cam that works :)
I hope they've got a lot of them in stock :)
What sort of frame rate/resolution do you get with it (and using what software?)
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
by lunix » Mon Jun 10, 2013 1:27 am
raspberrypiguy1 wrote:I've taken the £4.75 plunge and bought myself a PS2 Eye toy camera... We will see how that goes!
Clearly- you think you're awesome. We will see how that goes
