magtek card swiper?
by gworks » Fri Oct 26, 2012 11:49 am
magtek card swipers typically use keyboard emulation, they are more or less plug and play on any windows platform.
would it be that easy on the pi? Or would special drivers or software be required?
by rew » Wed Oct 31, 2012 12:54 pm
I suspect they just pretend to be a keyboard on the USB bus. The OS has no way of knowing it is not. So the 'pi will completely fall for the deception.
Conclusion: I think it will work.
Check out our raspberry pi addons: http://www.bitwizard.nl/catalog/
by dan3008 » Sun Nov 04, 2012 6:11 pm
I've had a usb barcode scanner working on the pi in exactally the same way :)
no reason why it shouldnt work that i can see, as long as it presents itself as a keyboard
dan3008 wrote:Pays your money, takes your choice
