fingerprint sensor
by slop241 » Sun Feb 09, 2014 4:35 pm
Greetings, I purchased this fingerprint sensor http://www.adafruit.com/products/751
and I put it to work perfectly with arduino .. my question is whether if is possible to connect with a
raspberry pi and more or less how this would be possible.
thank you very much in advance for your response
by DougieLawson » Sun Feb 09, 2014 4:58 pm
If you disable the serial console (update /boot/cmdline.txt and /etc/inittab to remove /dev/ttyAMA0 http://www.raspberry-projects.com/pi/pi ... /uart-pins) then you should be able to connect that TTL serial device on the UART pins RX 15 TX 14, 3V3 Vcc & GND.
There's even a script at: https://github.com/lurch/rpi-serial-console to query, disable and enable the serial console.
You should be able to get some data from the fingerprint scanner with:
import serial
ser = serial.Serial("/dev/ttyAMA0")
read = ser.read()
print read
ser.close()
Please post technical questions on the forum, not by personal message. Thanks.
Hacker on ZX80, Microtan65, Raspberry Pi & Arduinos
Mainframe Database troubleshooter
MQTT Evangelist
RPi owner since 2012.
Twitter: @DougieLawson
2B, B+, A+ & 5Bs
by slop241 » Sun Feb 09, 2014 5:31 pm
thank you very much for your response..i'll try it right now
by cisco_kid » Wed Jul 02, 2014 8:35 pm
slop241 wrote:thank you very much for your response..i'll try it right now
Did you ever get this to work?
