node.js i2c npm
by beatboxrevival » Tue Jun 04, 2013 7:11 pm
I created a node.js i2c package that works great with the Raspberry Pi. Check it out
https://github.com/korevec/node-i2c
by Wisar » Wed Sep 04, 2013 6:17 am
I have had some good results with this library until I upgraded Node.js to the latest stable release (v0.10.17) then boom, crash dump! Has anyone out there had success with this library on v0.10? I was upgrading in hopes of getting rid of some segmentation faults. If not v0.10 then what release is the latest with which this lib has worked?
Thanks,
Will
by skysedge » Wed Sep 04, 2013 6:48 am
Well done!
It will be nice to monitor data from my sensors attached to the Pi. I think that in combination with highcharts it is now straightforward to monitor your attached devices.
Best Regards,
by mrjansen » Tue Oct 22, 2013 11:54 pm
I am having trouble with this library as well. I am using two versions 10.x node - 10.9 and 10.21.
When I scan, the bus crashes and I can no longer see my device with gpio i2cdetect.
Also, when connecting the sample code on github is
var wire = new i2c(address, {device: '/dev/i2c-1', debug: true}); // point to your i2c address, debug provides REPL interface
Try that, but if it doesn't work, use
var wire = new i2c(address)
