Motorized Timelapse Camera Dolly
by michaelkoetter » Tue Apr 30, 2013 1:36 pm
I'm building a motorized camera dolly, to be used for timelapse photography - powered by a Raspberry Pi of course :)
The dolly is based on the Igus "DryLin W" rails, to which I attached a NEMA17 stepper motor and built a simple belt drive for the carriage. The stepper motor is connected to a Pololu A4988 driver which in turn is connected to the Pi's GPIO (the STEP and DIR pins for now). This way I can drive the motor by simply triggering a GPIO pin repeatedly.
I also built a simple camera trigger using a ULN2803 (which is overkill, I only need one of its drivers for the trigger... ). This could be used to trigger any camera that has a simple "switch" style remote connector, like Canon or Nikon DSLRs.
The Pi is running a node.js server, containing the software which controls the timelapse sequence (basically an interval timer + motor control). It has a small web frontend for mobile phones.
The Pi acts as a Wifi access point, so you can just connect to it with your mobile and control everything via the webapp.
interface1 von CmdrCord auf Flickr
interface2 von CmdrCord auf Flickr
Everything is battery powered of course, with a mobile battery pack for the Pi and eight AA cells for the motor (needs more than 9V).
This image shows what the whole rig looks like.
dolly von CmdrCord auf Flickr
(from left to right: mobile battery pack, AA battery pack, Pi, case with motor controller, motor - everything held in place by velcro tape :))
And this is the first test footage, it's only a 10sec clip but it's a start :)
http://vimeo.com/65010612
I'm planning to release the source of the software and schematics for the electronics once it is a bit more stable and has some needed features (like a "power saving" feature for the motor).
Right now I'm trying to add gphoto2 support, so the software could also change camera settings during the timelapse sequence. Might be useful to implement an "exposure ramp" feature or maybe even change the focus distance over time, we'll see...
If you can think of a useful feature, or want to help (some JavaScript skills required), please let me know!
by joan » Tue Apr 30, 2013 2:46 pm
Good project. Lovely city!
by imago6842 » Mon Jun 03, 2013 12:08 pm
Hi, great project, I´m build one whit arduino mega and a servo, but this project to controller whit the smartphone is great.
by Boyle » Thu Jul 24, 2014 2:02 pm
Great realization! I'm building nearly the same set. It would save me a lot of time if you would share your code. Did you already publish it somewhere?
Thanks!
Michael
